Thread: E85 vs Intercooled pump gas
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: E85 vs Intercooled pump gas
    SE Level Member wyoprix's Avatar
    cheyenne wy
    can u run e85 on 44s or would i need 60s
    2007 gt 3.0 mps 0-KR headers 3''dp cat res delete 44 injectors 85MAF stage 3 intercooler 108 t stat cold air, overkill pcm, aeroforce gauges tripple pillar, rims tint, trans cooler intense shift kit, yella terra 1.9 roller rockers 105 crow springs, 104 plugs, 7'' pioneer screen 1000 watt rockford amp an two 10" P3's cusom box & more
  2. #22 Re: E85 vs Intercooled pump gas
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    60s would be the best option
    If You Cant Hear The Whine You're Too Far Behind...
  3. #23 Re: E85 vs Intercooled pump gas
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    E85 is great for forced induction if that is what you are asking.
    If you are looking for which fuel has more "power"...its regular gasoline. Gasoline has more btu per unit than E85/ethanol.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #24 Re: E85 vs Intercooled pump gas
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by LeadfootCJ7 View Post
    Just a heads up someone is about to tear apart the last part of your statement there..^^^^^
    The quick version as I understand it is that Gasoline is run at 14.7 parts air to 1 part gasoline. E85 is run at around 12:1 to burn best (stochiometric) since you have a higher fuel to air ratio you get more power. That's why drag cars run nitro-methane. It runs at 3:1 I beleive.
    Also e85 burns cooler which is better for your engine. BTU's have nothing to do with power as far as I know. All BTU's is is a measure of heat output. More would actually be worse.
    I went NA when a whore left -$300 in my bank account.
  5. #25 Re: E85 vs Intercooled pump gas
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    In mentioning a "sweet spot" between ignition timing vs. boost... I personally found with my setup that running nearly stock timing tables and just adding boost was the best approach. I have been able to make more power just by leaving the stock timing table alone and adding boost vs. increasing timing at a lower boost setting. The second of the two still resulted in KR where as stock timing and added boost resulted in knock free power!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  6. #26 Re: E85 vs Intercooled pump gas
    Oct 2012
    Houston, TX
    Quote Originally Posted by indygrandprix View Post
    You are talking about changing other factors. I am talking strictly the product. I deal with refineries, analysis of products, etc for a living. Ethanol has less btu than gasoline (RUG) period. Can you modify things to make it work better in certain applications sure. But apples to apples it has less btu. That's why regular N/A cars that can run both get significantly worse mileage running e85 than straight gasoline. That's why people finally learned it costs more to run e85 in flex fuel cars even though the fuel is cheaper and fewer stations are offering e85.
  7. #27 Re: E85 vs Intercooled pump gas
    Exactly e85 for a na car is pointless. Only reason for e85 is for the ability to run more boost without knocking its pretty much that simple. Of course its going to get worse mileage. Most people after the hp and performance potential could care less about the mileage loss.
  8. #28 Re: E85 vs Intercooled pump gas
    Feb 2009
    flintnasty MI
    Brz frs guys are paying thousands to switch to e85 because they make 15whp gains on it with alot more torque.
  9. #29 Re: E85 vs Intercooled pump gas
    Lol paying thousands to switch...... Fools dont they have any tuner support yet? Id think by now them cars do.
  10. #30 Re: E85 vs Intercooled pump gas
    Arizona
    After running e85 since christmas . I can say its a worthwhile fuel if you can tweak your timing where it needs to be. But e85 no doubt sucks on the highway for mileage. City driving however is barley a hit and at 2.99 a gallon compared to 3.70 for premium.
  11. #31 Re: E85 vs Intercooled pump gas
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    They have a bunch of tuning solutions but the tuning shops market it as "super hard to tune and really corrosive" so they sell fuel line replacement kits injector seals and flex fuel sensors.
  12. #32 Re: E85 vs Intercooled pump gas
    Mar 2014
    Cincinnati, OH
    Are those flex fuel sensors something worth investing in for these 3800s, and would they even be compatible with our ECUs?
    I am guessing even with the flex fuel sensor, our stoich targets can't be changed on the fly like that without an ECU reflash??
    2002 GTP sedan:
  13. #33 Re: E85 vs Intercooled pump gas
    Feb 2009
    flintnasty MI
    I could probably design a flex fuel sensor that works, but its not worth it.
    GM cars that are flex fuel dont even use a flex sensor, they just use the o2 sensor.
  14. #34 Re: E85 vs Intercooled pump gas
    Arizona
    Gm cars used both, the majority use a external physical flex fuel sensor with a alcohol %table to adjust the stoich.
    Gm tried using a virtual flex fuel algorithm for a couple years but went back to a physical sensor.
    Keep in mind with that the car needs to have a voltage input based off of stomach that changes the master stomach table for the car to run correct.
    I find it easier just to reflash the car between summer/winter blend
  1. going intercooled
    By hollas13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 10:59 PM
  2. intercooled people
    By redlinepontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 11:47 AM
