Thread: Cooling system help
Results 1 to 6 of 6
  1. #1 Cooling system help
    Mar 2014
    A2 MI
    http://www.gpona.com/forums/viewtopic.php?t=31950 here is the original post need help so I can have my car back to normal with out the engine Temps spiking Everytime I stop. I know there is air in the system I just can't seem to get it to bleed out
    Sent from my SM-G900P using Tapatalk
  2. #2 Re: Cooling system help
    St. Louis
    Per Scotty-
    open the rad cap (while car is cold), start engine and let the car idle till the fans come on, then open the bleeder screw till a solid stream of coolant comes out. then shut the screw, top off the rad,and cap it.
    if your having a heat problem, take the hoses for the core off the engine and flush/fill the core. bleeding the engine wont help get the heat back.
  3. #3 Re: Cooling system help
    If you have air trapped and can't seem to get it out. Remove the two 10mm bolts on the thermostat housing and pull the thermostat. Fill right into the lower intake, then replace stat and housing.
  4. #4 Re: Cooling system help
    Mar 2014
    A2 MI
    My heat works I just replaced water pump and elbows they went out on me on my way home so coolant went every where
  5. #5 Re: Cooling system help
    Ok, if you still think you have some air.. overfill the overflow bottle and let the engine get up to temp and cool down a few times.
    Or... get yourself the best coolant funnel on the market.
    http://www.amazon.com/Lisle-24680-Sp...s=lisle+funnel
    I slap Mr. Funnel on there and run the car. It is the best funnel I've ever used for cooling systems.
  6. #6 Re: Cooling system help
    GT Level Member aligater's Avatar
    london ontario canada
    That funnel is awesome, but there was that one time it went flying and took out the bulbs on the ceiling. Be careful when working with hot fluids.
    I have my way but maybe there's a right way to do it.
  1. Cooling System Help
    By DrKavorkien in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2012, 01:10 AM
  2. Air in Cooling System?
    By tuchek in forum General Tech Discussion
    Last Post: 02-06-2012, 07:04 PM
  3. Hello Everybody, I'm having problems with my cooling system
    By ljatkins in forum General Tech Discussion
    Last Post: 10-14-2011, 08:09 AM
  4. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
  5. Cooling system bleeders
    By JenHello in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-21-2009, 09:52 AM
