Maf sensor and injectors are the biggest parts of tuning.. the rest of the mods do not change your tune at all actually.
Basically aside from some trans tweaks and a few tweaks to timing the only areas you need to worry about is finding the rigbt maf table for your maf and installing it into the file and changing your injector constant. Fine tuning is typically not needed and most people go backwards after they put a good base tune on.
With that cam I will also suggest running open loop as it will make tuning and driving it much much easier and consistent.
