Thread: Multiple Problems
Results 1 to 15 of 15
  1. #1 Multiple Problems
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    Just got my car put back together. Blown head gasket... I have a 2000 GP with a top swap and xp cam. These problems I had before I blew a head gasket...When I'm open throttle the car shifts way too early into 2nd then hesitates like it wants to shift again as I stay WOT. I did a few WOT runs with the car manually in 1st and it shifted fine. What could this be? ALSO, no Check engine lights.
    Another problem I had before was a rough idle. It surges up and down. All new gaskets from the heads up. New injectors at .050. Plug wires are maybe a year old. It has a new PCV. Could it be bad Coils??
    AC was just completely done today as well. New...compressor, Evaporter, Condenser, Orifice tube, High pressure switch. AC was working good earlier until just now when the passenger side is blowing cold and the driver side not so much. Driver side is getting cooled a little. I remember reading about this problem before but I forget what the solution was....
    Any suggestions would be highly appreciated!
    Thanks,
    Steven
  2. #2 Re: Multiple Problems
    TPS and MAP do have a good amount to do with shifting. Confirm which MAP you should have based on your tune and I'd also watch the TPS on a scanner to see that it's reading properly.
  3. #3 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    Ok I'll check those out.
  4. #4 Re: Multiple Problems
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I'd also look into the MAF sensor. Try unplugging it to see if your idle changes. I've had bad MAF sensors on a few GM cars cause all sorts of goofy stuff to happen.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    I think I've checked the MAF a while back, but I'll check it again.
  6. #6 Re: Multiple Problems
    St. Louis
    On the A/C thing, be sure that the system is full on R134. Often when they get low it blows warmer out the drivers side. Might be a small leak in the system somewhere still. Did you do the A/C work? If so, did it hold vacuum when drawn down before filling with freon?
  7. #7 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    Quote Originally Posted by FordMan77 View Post
    I read up on that the other day. I did not do it myself. I'll probably take it back to the guy I know that did it.
  8. #8 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    I also read that it could be the blend door actuator. I messed with the AC some more yesterday...I put the temp all the way over to heat on the diver side control and the air pressure went way down out of the drivers side vents. Temp stayed the same because I bypassed my heater core. Put it back to cold and the pressure picked up. I put the passenger side to heat and the pressure stayed the same...Does this mean my blend door actuator is bad on the drivers side??? I remember I replaced the passenger side actuator several years back, but don't remember what was going on that made me change it.
  9. #9 Re: Multiple Problems
    take the driver side one off and turn it by hand, see if it gets cold.
    sometimes pulling the climate control fuse will reset the actuators. i just pulled my cc out to repair it and the d/s went hot on me, unplugged it and back in and all was well again.
  10. #10 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    I have 2 codes. P1133-Heated Oxygen Sensor Insufficient switching sensor. P0171-Bank 1 system too lean.
    So theres 2 oxygen sensors? I know of 1 down by the cat. Could these sensors be causing a rough idle?
  11. #11 Re: Multiple Problems
    Bank 1 would be the o2 on the manifold bank 2 is the one after the cat.
    04 Comp G.
  12. #12 Re: Multiple Problems
    St. Louis
    P0171 is usually a vacuum leak or a cracked EGR pipe (if it's not deleted).
  13. #13 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    On the manifold? Where exactly is that? Would kind of problems could that cause?
  14. #14 Re: Multiple Problems
    May 2012
    Phoenix, AZ
    The gasket for the egr pipe may be a little roughed up if I remember correctly. Could that be causing a vacuum leak?
  15. #15 Re: Multiple Problems
    St. Louis
    Yes. Also, bank 1 O2 sensor is on top of the rear manifold, just left of cyl. #6 spark plug.
  1. Multiple Engine codes - Multiple Cylinder misfire etc...
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2014, 04:31 PM
  2. Multiple EGR Codes
    By rbob900 in forum General Grand Prix Discussion
    Last Post: 04-05-2013, 04:23 PM
  3. 2000 gtp multiple problems....HELP
    By tjfrey517 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2012, 07:29 AM
  4. multiple issues, help?
    By Brammer in forum General Tech Discussion
    Last Post: 10-04-2010, 03:37 PM
