Thread: Boosting High Compression vs Low Compression M90 Setup
Results 1 to 20 of 28
  1. #1 Boosting High Compression vs Low Compression M90 Setup
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hey guys,
    I know this question comes up often on various forums (High Compression/Low Boost vs Low Compression/High Boost) but I'd like to limit the discussion to the Eaton M90 on the 3800SII.
    If I am putting together an engine build, say a 350-400bhp setup, and I am limiting myself to using the M90... does the L36 make more sense than the L67? (I'm not really talking about a simple top swap, but rather, building an engine from the ground up.)
    My understanding is, both blocks can handle this horsepower range as long as detonation is prevented. Since the L36 can make more power with the same amount of boost as the L67 (assuming no knock), I would assume that you can run closer to the stock pulley than you could with an l67.
    So rather than running a tiny pulley, which creates more drag on the crank, and generates more heat... why not just run a bottom end with more compression, and a bigger pulley? Seems like a much more efficient setup.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Boosting High Compression vs Low Compression M90 Setup
    From what I understand zzp uses a l36 in their setup so I think what you are saying makes sense. In theory you can make more power with less boost.
  3. #3 Re: Boosting High Compression vs Low Compression M90 Setup
    I like the dished pistons on the L67 though, only reason why I would stay with a lower compression block.
    Another way to look at it is, you don't always have to run the really small pulley. You can use timing to your advantage if using a 93 octance + meth and or E85 fuel, then you could run a 3.0ish pulley with extra timing to be at the same level as a 2.8ish pulley.
  4. #4 Re: Boosting High Compression vs Low Compression M90 Setup
    typically you'll run out of pulley options with the L67 block a lot sooner, but setup right both are capable of spinning the m90 way out of it's efficiency range.
  5. #5 Re: Boosting High Compression vs Low Compression M90 Setup
    Apr 2011
    Vassar, Mi
    Exactly, if your going for maximum power and plan on running enough octane to support it high compression will get you further. Once the m90 is out of steam you have to make power somewhere else, at that point more compression and better airflow are your only options. Or nitrous that works too I guess.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  6. #6 Re: Boosting High Compression vs Low Compression M90 Setup
    SE Level Member 13aceofspades13's Avatar
    Oct 2013
    Ionia
    the L-36 and L-26 Pistons are less dished for higher compression, this makes it a very common practice to do a "Bottom end swap." this allows the some 9:1 higher compression ratio of the N/A 3800s... HOWEVER consider this, the connecting rods on the L-36 and even the L-26 are not as heavy duty as the L-67 L-32 engines. if you start pushing 500HP or 350 with high revs you could be dealing with broken rods or spun bearings!
    my advice if you really want too push power, go with a L-67or L-32 bottom end for a budget, or "race prep." your own, you can get high strength connecting rods and ceramic coated pistons through ZZP, and you can get the crank and the rest of the assembly balanced so then you can have the higher power rating and revs and not worry about spinning a rod, then you can compensate the compression for higher boost.
    "Foxy" 2008 Pontiac Grand Prix Base model, Intake, 5.5 water pump pulley, thrush turbo muffler, flipped dogbones, MSD 8.5MM super conductor Wires, Accel super coils.
  7. #7 Re: Boosting High Compression vs Low Compression M90 Setup
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    But the cost of machine time would be crazy. I doubt the N/A bottom ends are a that much weaker than SC cars.
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Boosting High Compression vs Low Compression M90 Setup
    most likely you'd chip a piston before bending a rod. just about every time.
  9. #9 Re: Boosting High Compression vs Low Compression M90 Setup
    Cheap ****ty pistons that have seen KR for years are going to be weak as hell.
    Also, apparently L36 rod bolts like to let go from time to time. It's a fun time, when you're spinning into the mid 6's on a stock bottom end.
    Quote Originally Posted by Turbocharged400sbc View Post
    if ya want more compression from the 67/32 then just use two layers of the MLS HG and bump it up .4
    Mmm, all that quench.
  10. #10 Re: Boosting High Compression vs Low Compression M90 Setup
    Next motor I'm building is going to have a stock L36 bottom end
  11. #11 Re: Boosting High Compression vs Low Compression M90 Setup
    Florida
    Either motor will work fine as long as you build it accordingly.
    For a high power build, it's foolish to do anything but turbo it.
    For a strictly M90 blower setup though, you're going to need a big lump stick (with supporting mods) and ported heads/matching LIM.
    Stick with a "larger" pulley (3.0-3.2) and run a bunch of timing. If you are able to get away with 24+ degrees or so with no knock, start dropping pulley sizes.
  12. #12 Re: Boosting High Compression vs Low Compression M90 Setup
    Willoughby, Ohio
    you sir have the same mindset I do. rather than running out of pulley options, go L36 bottom end and keep the blower much happier and have options for modding in the future. and as stated above, build it right and eliminate knock and you will not have issues
  13. #13 Re: Boosting High Compression vs Low Compression M90 Setup
    I have a l26 bottom end in my car, they are cheep as dirt and almost always have low miles too.
  14. #14 Re: Boosting High Compression vs Low Compression M90 Setup
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    I don't believe in boost + high compression in a pump gas scenario. Even race machines, I've seen better results with reasonable compression + very high boost (turbo)
    S/C is another story with efficiency dropping so quickly and HP loss through driving the S/C. Stock compression for pump I think is better in general.
    For a completely maxed out M90 on pure race fuel high compression is the way to go.
  15. #15 Re: Boosting High Compression vs Low Compression M90 Setup
    timing is harder to run consistently versus more boost due to fluctuations in weather and octane of fuel.
    however, boost > timing is a turbo mentality, too.
  16. #16 Re: Boosting High Compression vs Low Compression M90 Setup
    May 2013
    Gatineau
    S/C reduces the boost vs Timing advange but it's still there, especially intercooled. But at one point too small pulley and no intercooler makes it very difficult to get rid of knock.
  17. #17 Re: Boosting High Compression vs Low Compression M90 Setup
    i'm a firm believer if that i can't roll up to a gas station and be forced to run 91 and not worry about destroying it then i didn't build it big enough.
    i love ethanol, methanol, and race gasses, but i'm just not a dedicated race car fan so being able to street drive it and fill up wherever i end up is a key thing to me about any car i put together.
  18. #18 Re: Boosting High Compression vs Low Compression M90 Setup
    Apr 2011
    Vassar, Mi
    This is what I'm talking about, here is where I'm at. Maxed m90 (2.7 on a genV), maxed timing (22-24*), and I still have plenty of headroom for KR on E85 but no way to use it. That 9.5:1 sure sounds good about now. You will max out an M90 very easily and still be left looking for more power. At this point there is nowhere to make more power with the system without rebuilding the valve train with a bigger cam and expensive ported heads.
  19. #19 Re: Boosting High Compression vs Low Compression M90 Setup
    May 2013
    Gatineau
    Quote Originally Posted by Anthony Smith View Post
    Pretty impressive you are able to run such a small pulley and that much timing without any knock even on E85. That STG2 IC is doing its work !!
  20. #20 Re: Boosting High Compression vs Low Compression M90 Setup
    hangover park IL
    l26 rods will snap if you look at em wrong, l36 is the only way to go unless yer considering spray, then is a l67/32
    ~James~ Psychotic Gearhead
  1. low compression on number 5
    By chrisferguson84 in forum 5.3L V8 (LS4)
    Last Post: 02-04-2014, 06:15 PM
  2. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  3. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  4. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
