Thread: L32 Injector Upgrade
Results 1 to 20 of 25
andrewpetty24 L32 Injector Upgrade 07-04-2014, 02:53 PM
matt5112 Re: L32 Injector Upgrade 07-04-2014, 06:04 PM
wa04compg Re: L32 Injector Upgrade 07-04-2014, 07:53 PM
matt5112 Re: L32 Injector Upgrade 07-04-2014, 08:04 PM
wa04compg Re: L32 Injector Upgrade 07-04-2014, 08:10 PM
wa04compg Re: L32 Injector Upgrade 07-04-2014, 08:23 PM
matt5112 Re: L32 Injector Upgrade 07-04-2014, 08:39 PM
wa04compg Re: L32 Injector Upgrade 07-04-2014, 10:52 PM
andrewpetty24 Re: L32 Injector Upgrade 07-05-2014, 04:20 AM
matt5112 Re: L32 Injector Upgrade 07-05-2014, 06:03 AM
wa04compg Re: L32 Injector Upgrade 07-05-2014, 09:35 AM
91parkave Re: L32 Injector Upgrade 07-05-2014, 09:47 AM
wa04compg Re: L32 Injector Upgrade 07-05-2014, 09:51 AM
wa04compg Re: L32 Injector Upgrade 07-05-2014, 10:36 AM
andrewpetty24 Re: L32 Injector Upgrade 07-05-2014, 04:06 PM
91parkave Re: L32 Injector Upgrade 07-05-2014, 05:07 PM
andrewpetty24 Re: L32 Injector Upgrade 07-05-2014, 03:56 PM
andrewpetty24 Re: L32 Injector Upgrade 07-05-2014, 06:24 PM
91parkave Re: L32 Injector Upgrade 07-05-2014, 08:15 PM
andrewpetty24 Re: L32 Injector Upgrade 07-05-2014, 11:54 PM
wa04compg Re: L32 Injector Upgrade 07-06-2014, 12:25 AM
matt5112 Re: L32 Injector Upgrade 07-06-2014, 11:23 AM
andrewpetty24 Re: L32 Injector Upgrade 07-07-2014, 04:58 AM
wa04compg Re: L32 Injector Upgrade 07-07-2014, 11:04 AM
wa04compg Re: L32 Injector Upgrade 07-07-2014, 11:07 AM
  1. #1 L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    I have an '05 COMPG and i was looking at installing bosch blue giants instead of going with green giants and having to buy adapters or replace the connectors. has anyone done this already and knows of a thread? and what are the o-ring diameters for this motor? one site i found offered 11mm or 14mm o-rings with the injectors so i'm curious. obviously i would be getting a tune and doing some other mods but i just want to know if someone else has done this and knows more
  2. #2 Re: L32 Injector Upgrade
    If the blue giants are the same body style as the green giants, stay away. The spray pattern is all wrong your for car.
    They're fine for four valve heads, but for two valve heads: terrible. You'll just line the intake runner walls with fuel causing all sorts of weird things to happen at situations like warm up and low load.
    Your car has a 60 mm o-ring to o-ring height and they are both 14 mm.
  3. #3 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    I have 04 cobra blue injectors if that's what you are referring to and have no issues to speak off
    08 G8 GT - exhaust Tune
  4. #4 Re: L32 Injector Upgrade
    I had them, and didn't like them. My car didn't know what the **** it was doing when cold, and kept changing the warmer the car got.
    The idea is the fuel hits the intake runner walls, which evaporate the fuel at different rates based on the temperature of the air, fuel and most importantly the runner wall itself. If you want a little more on it, read this: http://www.megamanual.com/ms2/xtau.htm
    Claiming you have no issues is risky business. You could have tip-in fueling issues, running rich/lean during engine warm up etc. Essentially things that most would put down as driveability or emissions. Things that tend to get overlooked. Without proof, which means datalogs with a calibrated WB, we're both flying blind here.
  5. #5 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    I have a wb and I haven't had a issue like I said I have read all about the spray pattern a guy on hpt used them on 04 with good results comes down to opinion I guess
  6. #6 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    Was your issue on cold start? Mine does tend to hard start when warm but only after it's sat for 10+ mins
  7. #7 Re: L32 Injector Upgrade
    Fueling was all over the place.
    Sold them, bought different injectors.
  8. #8 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    How much would your afr vary?
  9. #9 Re: L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    so if i want to bump up to 42# injectors, what should i look for? any particular brand or just a different spray pattern?
  10. #10 Re: L32 Injector Upgrade
    Honestly, I don't remember. It was two years ago now. I lost the USB flash drive with all of my hpt files on it as well. I recall it wasn't good enough, and the Lucas 42s I sold did a much better job. That'd be my recommendation given the price.
  11. #11 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    Zzp sells 42's for like $250....another guy on here found pickup flex fuel injectors that will work with spacers...overkill has decent priced injectors also
  12. #12 Re: L32 Injector Upgrade
    Arizona
    You 3800 guys should be taking advantage of cheap LS injectors...plus all the data is readily available to plug in.
  13. #13 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    ^listen to him!
  14. #14 Re: L32 Injector Upgrade
    Oct 2011
    Puyallup WA
    I bought the cobra ones because they where $130 and I just plan to use them temp...going to turbo in the near future so will need at least 60's for that....
  15. #15 Re: L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    where in arizona are you at 91parkave?
  16. #16 Re: L32 Injector Upgrade
    Arizona
    Quote Originally Posted by andrewpetty24 View Post
    south of tuscon 45min. Sierra vista
  17. #17 Re: L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    i thought about the 60's but im not doing any heavy modding anytime soon as its my daily driver so 42's are really all i need till i build a motor for it i think.
  18. #18 Re: L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    oh nice like on the border then. cool. i was just curious cause i see a white gxp in my area as well
  19. #19 Re: L32 Injector Upgrade
    Arizona
    Yea theres a border patrol agent with a bone stock one..ive seen him a couple times when i come up there
  20. #20 Re: L32 Injector Upgrade
    Jun 2013
    Tucson, AZ
    in regards to the blue or green giants spraying wrong, should i be looking for a particular spray pattern? i had thought that a cone pattern s better than a pencil stream but the best would be a "fog"?
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. 04 gtp injector.
    By Toms04compg in forum General Tech Discussion
    Last Post: 04-18-2012, 11:34 AM
  3. SES Code after injector Upgrade
    By FastKatt in forum PCM Tuning
    Last Post: 05-13-2008, 08:27 PM
