Thread: Boosting High Compression vs Low Compression M90 Setup
Results 1 to 20 of 28
  1. #1 Re: Boosting High Compression vs Low Compression M90 Setup
    I have a l26 bottom end in my car, they are cheep as dirt and almost always have low miles too.
  2. #2 Re: Boosting High Compression vs Low Compression M90 Setup
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    I don't believe in boost + high compression in a pump gas scenario. Even race machines, I've seen better results with reasonable compression + very high boost (turbo)
    S/C is another story with efficiency dropping so quickly and HP loss through driving the S/C. Stock compression for pump I think is better in general.
    For a completely maxed out M90 on pure race fuel high compression is the way to go.
  1. low compression on number 5
    By chrisferguson84 in forum 5.3L V8 (LS4)
    Last Post: 02-04-2014, 06:15 PM
  2. No compression
    By carbon in forum General Tech Discussion
    Last Post: 12-22-2011, 09:12 PM
  3. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  4. Bad Compression?
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2009, 01:22 AM
