Thread: regal top swapped problems
Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 288
  1. #81 Re: regal top swapped problems
    Ok...personally having dealt with top swap tuning and crap, I can tell you that your tune is junk and is the reason for most of your problems. Before a retune, make positively sure that you have no vacuum leaks as the new tune will be affected by it. Then, listen to whatever Bill tells you and get help from whomever he is sending you to as Bill won't steer you wrong.
    The tune you have is fine. Zzp has done a top swap before.
    This is one of the things that really grinds my gears on here, 2 different people will post that something is either junk or good without either person stating why/how they know.......And saying that ZZP has done a top swap is before is not really a reason. Sven how do you know that the tune is junk? You aren't driving his car, you haven't looked at a bin of his tune so without doing either you have no real way of telling this. DH pretty much what I just told Sven...
    /end rant
    On a side note, since your car is a 97 a lot of your readings are going to be backwards or negative numbers since your car is a 97, my 97 GTP showed a lot of stuff in negative numbers.
    [IMG][/IMG]
  2. #82 Re: regal top swapped problems
    Jul 2014
    colorado
    Um no it sounds like its about to die and then it reva to the idle rpm. Like it has a vac leak or the maf is about to go out. Because now im recieving aa long start once sitting for while. Also it hesitates sometimes when starting again like its going to die out and then it revs and goes to idle. You can hear in the engine when you try to start it how the idle sounds like it wants to die but doesnt.
  3. #83 Re: regal top swapped problems
    Check your fuel pressure regulator. Mine would be a huge pain to start when it sat for a day or so, sometimes it would flood itself out, then I replaced the fuel pressure regulator and it started and ran fine afterwards.
  4. #84 Re: regal top swapped problems
    i know you've tried this and that. but have you tried to unplug the maf, then start it? if it runs better the maf is super dirty or bad.
    or the wires to the maf could be damaged from heat over the years.
    just another shot in the dark not being there with it of course.
  5. #85 Re: regal top swapped problems
    Jul 2014
    colorado
    Yeah with my maf unplugged my car runs like poopy lol. Barely stays started and dies really quickly with it unplugged. Its a remanufactured one by gm has the sticker on it and everything. As for the fuel pressure regulator ive unplugged it and let run while i watched for gas to spew but no dice
  6. #86 Re: regal top swapped problems
    im out of idea's. sorry. what a pita this one is.
  7. #87 Re: regal top swapped problems
    Just out of curiosity are you running the l67 injectors or the l36 injectors?
  8. #88 Re: regal top swapped problems
    Jul 2014
    colorado
    L67, you cant run l36 injectors they are to short or fat. Something like that. But my tune from zzp asked what injectors were in it and i put l67 injectors so
  9. #89 Re: regal top swapped problems
    Jul 2014
    colorado
    Idk that seems like a vac leak soo bad dude. My explorer used to do the same thing and turned out to be a vac leak. But ive replaced all hosing, and sprayed for leaks. I'm going to replace the wires again. What should i get because acdelco isnt working for me. Coulda got a bad set of wires?
  10. #90 Re: regal top swapped problems
    Donating Users timboku's Avatar
    Montgomery, IL
    Maybe some pics of your engine bay so we can see how you have the lines run anything outta the ordinary..it sounds like a big vac leak..is the sc torqued down, egr piple ok? They leak all the time?
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  11. #91 Re: regal top swapped problems
    Jul 2014
    colorado
    Yeah my dad used the torque wrench on the heads, lim, supercharger ect. All to specs using the torque specs page on regalgs forum. As for egr stove pipe. It went on fine i didnt bend it all out of wack when doing the swap. As for pictures will do coming shortly
  12. #92 Re: regal top swapped problems
    Jul 2014
    colorado
  13. #93 Re: regal top swapped problems
    Feb 2009
    flintnasty MI
    i sorta doubt that the tune supports a 2bar map... I would try unplugging it.
  14. #94 Re: regal top swapped problems
    Montgomery, IL
    Do u have a vac line going to.the bbv solenoid?..cant really see it in the pic
  15. #95 Re: regal top swapped problems
    Jul 2014
    colorado
    Yes i do its under the mess of wires next to the cylinder which i think is what your talking about, and ive already unplugged the map sensor... does absolutely nothing
  16. #96 Re: regal top swapped problems
    Jul 2014
    colorado
    Also gotta put somethings in laymen terms. Jimmies sometimes doesnt understand certain car lango, whats a bbv solenoid
  17. #97 Re: regal top swapped problems
    it looks like your missing a vac line to the bbv. unless its looped in a way i cant see it.
    this one in my pic goes from the snout to the fpr to the bbv. other side of my snout T goes to the map sensor.
  18. #98 Re: regal top swapped problems
    Montgomery, IL
    http://ww2.justanswer.com/uploads/Vi...638_vacuum.jpg
    97 l67 vacuum line routing..make sure you got everything...theres 2 vac lines by the bbv..one to thr top of the sc which I see and one that connects to the seliniod shown in scottys pic above
  19. #99 Re: regal top swapped problems
    Jul 2014
    colorado
    That one is routed to my throttle body,
  20. #100 Re: regal top swapped problems
    Montgomery, IL
    U.need a line to.the bypass solenoid.under the boost bypass
  1. 98 GP GT L67 swapped needs pcm which one??
    By 98PONTIAC in forum General Tech Discussion
    Last Post: 12-27-2012, 03:14 PM
  2. 1998 Buick Regal Problems
    By MidnightBlue in forum General Tech Discussion
    Last Post: 12-14-2012, 01:35 PM
  3. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  4. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  5. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
