Thread: regal top swapped problems
Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 288
  1. #41 Re: regal top swapped problems
    some of the stuff on my slow screen. its over loaded, i have other pages with just KR.
  2. #42 Re: regal top swapped problems
    Jul 2014
    colorado
  3. #43 Re: regal top swapped problems
    Jul 2014
    colorado
  4. #44 Re: regal top swapped problems
    Jul 2014
    colorado
    These are at idle, the next 2 are at wot
  5. #45 Re: regal top swapped problems
    Donating Users timboku's Avatar
    Montgomery, IL
    If you add the gauge type that ahows you max and mins you can get a better take on whats happening espicially on wot runs
    Sent from my SCH-I545 using Tapatalk
    regal top swapped problems Attached Images
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  6. #46 Re: regal top swapped problems
    Jul 2014
    colorado
  7. #47 Re: regal top swapped problems
    Jul 2014
    colorado
  8. #48 Re: regal top swapped problems
    Timing is low, but without knowing if KR logging via Torque is actually working, or without seeing the bin/hpt of what's on your PCM, we can't know for sure.
    These snap shots don't help that much either. You need a log with multiple data points.
    Have you checked compression? Checked if the cooling system holds 15 PSI?
    I ask because the integrity of the cooling system is in question because you're not holding a solid temperature and recent major mechanical work was performed. These two checks would be an assurance that your work is sound, and the problem lies elsewhere.
    Did you solve the misfire issue yet?
    You're also doing no one any favours by having so many threads and cross posting on multiple forums. It makes it more difficult to keep track of what specific remedies you've tried, and with what results. Without that, making suggestions as to what to check is difficult and will result in what you saw on the first page.
  9. #49 Re: regal top swapped problems
    the boost was tim's post of his t app screen shot. lol
  10. #50 Re: regal top swapped problems
    Thanks. That car is messed up as well.
  11. #51 Re: regal top swapped problems
    Montgomery, IL
    Ya I had a vacuum leak under the dash and my 02 sensor was bad so.my trims and everything was wacked. I just posted that for him to.see what I do with my gauges on torque..lol..sorry didnt mean to confuse anyone.
  12. #52 Re: regal top swapped problems
    Quote Originally Posted by timboku View Post
    It was my fault for jumping the gun there. Sorry about that. Glad you fixed your issues though.
  13. #53 Re: regal top swapped problems
    Montgomery, IL
    Sorry it was the first pic I had should have posted a better one..car is fine that was over a year ago when I couldnt find a vac leak..lol
  14. #54 Re: regal top swapped problems
    Jul 2014
    colorado
    Ok time to butcher you down. I get you guys are trying to help but i have people telling me ok put this on there then screen shot and then here you are telling me those dont mean ****. As for the cooling system my father will do that tomorrow at our shop.
    Misfire: obviously not if theres videos of it. How do you know if it's a misfire you cant assume it is just like the rest of the other people on these forums tell me its multiple issues yet ive replaced everything that has to do with misfires. EVERYTHING.
    Also i made multiple threads because i think that having multiple people seeing whats going on it will give me for information as to what other think it is. Think scientifically dude. You cant do one test and thats it you gotta do multiple tp get different readings and opinions. All of these threads have the same information ive put into all the others. And if you go back to each one they were started during different problems . One was the stutter, the other was putting the dang thing together and the other was troubles during start up. I cant stress enough to REAAAAAAD THEEEEEM.
  15. #55 Re: regal top swapped problems
    It was unwise to top swap a broken car.
    Have a good day.
  16. #56 Re: regal top swapped problems
    Jul 2014
    colorado
    Its unwise for you to make prejudgemental recalls of past events that have been fixed. The vibration is gone after regapping the plugs. The car ran fine pther than what i thought was the torque converter not workimg correctly.
    It was working fine before top swapping. I didnt have a overheating issue, i didnt have the rough vibration issue, i didnt have the jerking/stuttering issue. This car ran literally fine until top swapping.
    Now any more questions?
  17. #57 Re: regal top swapped problems
    Jul 2014
    colorado
    The only thing i need looked at right now is the stutter at wot when at normal temp and why it gets worse when the ac makes the car heat up?
    My gauge shows im not getting knock at wot with multiple runs.
  18. #58 Re: regal top swapped problems
    Jul 2014
    colorado
    Your trying to make me look like im contradicting myself when in fact notice i say before i swapped?
    Also my idle according to the gauge on torque pro is saying im at 760 in park and 785 in drive
  19. #59 Re: regal top swapped problems
    load the misfire gauge if you can on the T app. see if it shows any. cause it seems like bad misfires to me. ignition related some how.
    could be a bad wire on the icm harness, like you pinched one, or by the pcm. they like to wear through on the a/c lines.
    if its worse when hot the icm could also be bad....i know i know it ran on the other car, f that, test it. its free at auto zone. icm's go bad. even seen em test good and still be bad. so maybe try a junk yard one.
  20. #60 Re: regal top swapped problems
    Jul 2014
    colorado
    Thanks Scotty yeah im going to go get it tested now and give you the results. Ill go to the junk yard tomorrow and go pull a couple if its the problem.
  1. 98 GP GT L67 swapped needs pcm which one??
    By 98PONTIAC in forum General Tech Discussion
    Last Post: 12-27-2012, 03:14 PM
  2. 1998 Buick Regal Problems
    By MidnightBlue in forum General Tech Discussion
    Last Post: 12-14-2012, 01:35 PM
  3. Top swapped
    By Dragon1972 in forum PCM Tuning
    Last Post: 05-03-2012, 09:07 AM
  4. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  5. 2002 Regal GS motor/trans swapped into a 97 GTP??
    By toast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 11:05 PM
