Everyone, I've been lurking here recently because of intermittent hard starting and stalling issues on my 2002 Buick Regal GS. I'm clueless as to what the real problem is until I investigate tomorrow afternoon. I want to check the fuel pressure regulator but I don't know where it is.
I'm also going to check the fuel pressure. So far, it might need a fuel pump, fuel pump resistor, fuel pump regulator, crank position sensor or a mass airflow meter. Is that correct? Have I missed anything?
Also, does a 2002 still have a fuel pump resistor or was the pump changed to a venturi style that does not need the resistor? (I've not been able to confirm this portion.)
Thanks in advance!
