Thread: Finally Running, but stalls
Results 1 to 14 of 14
  1. #1 Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    Ok, spent some time on the car yesterday. When i first pulled out i got on it pretty good to get into boost and it cut off. Driving regularly, it does the same thing bout a mile or two round town. Unplugged the MAF and it still does it. Changed the MAF, still does it. Goin up a hill and it cuts off. It always starts back up, but if i hit it too hard it will not stay on. It was also surging pretty bad. Jumping by like 500-1000 RPM.
    Will it was pushing itself.
    I got a couple codes, P0107, P0127, P0443. On my way this morning after i drop my daughter off to grab a TPS and IAT sensor from the yard. Hopefully this will knock it out..thoughts?
  2. #2 Re: Finally Running, but stalls
    Can you please tell us what those code names are. Thanks
  3. #3 Re: Finally Running, but stalls
    Aug 2013
    arlington, tx
  4. #4 Re: Finally Running, but stalls
    HUDSON
    Sounds like low fuel pressure problem.
  5. #5 Re: Finally Running, but stalls
    SE Level Member 97grandprix1's Avatar
    Apr 2014
    Post Falls Idaho
    Yep
    97 GTP / new head gaskets / plugs and wires / 180 stat / U delete / 3" cat back to v-force / rebuilt S/T / cone filter......Family car, we're not station wagon people
  6. #6 Re: Finally Running, but stalls
    Aug 2013
    arlington, tx
    Sounds like what my car was doing and it turned out to be my MAP sensor. I cheaped out and bought one from oreillys instead of OEM and it bit me in the ass in the end but mine is N/A not SC.
  7. #7 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    Ok, i went and grabbed a MAP sensor from the JY and a spare MAF and threw it on this morning before work and it
    does the same thing. Went to scan it and it showed all zeros under the MAF. Even when im on the gas. So, i guess
    i should try a brand new MAF? Which sucks, cause the "friend" who put the motor in took the MAF i had put a bs one on.
    I guess he thought i wouldnt notice
  8. #8 Re: Finally Running, but stalls
    Aug 2013
    arlington, tx
    Did you disconnect the battery to clear the codes/ reset the system?
  9. #9 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    I did not. Ill do that when i get home. Anybody ever used the cardone reman maf? Before i go buy it
  10. #10 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    Update:
    I went and got the Reman MAF from advance this morning, threw it in and disconnected the battery. It cleared
    the P0102, P0107, and P0140 codes that i was seeing. Took it out on the highway on my way to work and drove
    fine early on then cut off mid traffic doing bout 65. Pulled over gave it a min or two and it started back up and i
    got to work. Only issue was a high idle somewhere around 1500-2000 when i got it back started.
    i changed the crank sensor little over a year ago as well as the icm, but with how this guy screwed me over, he may
    have taken the parts back while it was in the shop...who knows
  11. #11 Re: Finally Running, but stalls
    Aug 2013
    arlington, tx
    Was there an issue before this started happening? Did you check out the video I had posted?
  12. #12 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    yea, i checked it, thx. this thing is crazy. the ignition can be started without the key. I went this morning and started it with the key and it started right up. Runs like sh*t but it runs. The P0140 came back concerning the o2 sensor in the rear, but i dont have a cat on the car and the exhaust is not completely sealed. Just chasing the issues down as they come to me.
  13. #13 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    Hate to bring back an old thread, but I just started driving this car again(03 GT) and its still doing the same things it was doing a few months ago.
    Only this time it only cuts off when im on the highway above 60mph. On the street in stop and go i haven't had an issue so far. The list of things
    that i had done goes as follows...
    1) Spark Plugs (Autolite 103's)
    2) ICM from a 80k motor
    3) Coil packs from 80k motor
    4) Reman MAF
    5) JY map sensor
    6) plugging in various vacuum lines
    7) JY IAC sensor
    What is causing this thing to cut off at high speeds? I tried the FP resistor trick, but i dont have the resistor because the car is a GT with the swapped motor.
    Also when i had snowflake do the computer i had him tune it for things that were later on stolen off the car. i.e. 1.85 YT's, Headers, walbro pump. Just to provide
    better background.
  14. #14 Re: Finally Running, but stalls
    Jul 2011
    Baltimore, MD
    nobody has any input?
  1. Running pig rich and stalls when warm
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 07:16 AM
  2. l67 engine wont stay running..got the car running. tons of white smoke from exhast
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 05:14 PM
  3. Know your car: What happens when the car stalls
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 05-30-2012, 03:46 PM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. The MP112 GTP Is FINALLY Running!
    By VinnieGTP in forum General Tech Discussion
    Last Post: 07-31-2008, 04:10 AM
