Thread: cranks no start
Results 21 to 40 of 46
  1. #1 Re: cranks no start
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    billl the plugs were wet... and i figured it to be the cam sensor.. brought a new one it was a dud.. got a replacement and got spark... nowww im being told the car has no compression in number 5 and 3.... i dont see how... the dam pistons moving and has no chips or anything... they say its at 0 and not even trying to climb... im stumped yet again
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: cranks no start
    if its been sitting a long time a valve seat maybe gunked up.
    a shot of sea foam may clear it up if it dont clear up on its own.
  3. #3 Re: cranks no start
    brunswick
    didnt think about that.. ill pour some in the oil and turn the car over
  4. #4 Re: cranks no start
    not the oil, god no!!! dont do that.
    suck it up a vac line while its idling, then shut it off and wait 20 minutes, then fure it back up and let it smoke.
  5. #5 Re: cranks no start
    brunswick
    it wont start
  6. #6 Re: cranks no start
    oh damn, you said it had spark i figured it fired up.
  7. #7 Re: cranks no start
    brunswick
    it has spark now.. the plugs were wet before spark so it has gas.. still no fire... i had the dots lined up and the #1 tdc you think its outta timing?
  8. #8 Re: cranks no start
    on the timing chain? that sounds right.
    dry the plugs up, crank the engine over with no plugs to blow out any left over fuel, and then see if it will fire up. even if 2 cylinders are low on compression it should fire up, run poorly but run.
  9. #9 Re: cranks no start
    brunswick
    hell on the block i just pulled it it had a chip piston in number 1 number 3 read 120 compression and number 5 was at 90 and car still ran strong.. so i dont know..
  10. #10 Re: cranks no start
    brunswick
    im thinking i should pull timing cover off and see how things are lining up... what exactly should i do to reassure that its right
  11. #11 Re: cranks no start
    brunswick
    Pulled case found it to be cracked to hell and timing dots not meeting so I adjusted cam and crank to meet as theyshould but ddidn't reassemble yet due to having to come to work
  12. #12 Re: cranks no start
    well thats a start, good luck.
  13. #13 Re: cranks no start
    brunswick
  14. #14 Re: cranks no start
    brunswick
    yea thanks man..
  15. #15 Re: cranks no start
    how in the hell did you crack the cover like that? make the bolts to tight or something? seems odd its cracked on both sides like that.
    and damn the other dot is no where in sight either.
  16. #16 Re: cranks no start
    brunswick
    man i think i dropped the old blcok on it or something honestly lol.. the way that crack is.. no way over tightening the bolts did that.. majority of them not even in the same spot...as the bolts.. and yea the dots were no where meeting.. one would be at 6 oclock the other was at 4 or 330 lol
  17. #17 Re: cranks no start
    lets hope a valve didnt meet a piston with the chain off by so much.
  18. #18 Re: cranks no start
    brunswick
    i didnt hear any clanking or pinging.. i doubt it did with just turning over... but time will tell
  19. #19 Re: cranks no start
    Jan 2014
    AR
    If the crank is on the correct rotation vs the cam and the dots line up you should be golden. If you got a new timing cover. Man I hate seeing busted castings. I've thrown timing chains at idle with a couple V8s and the first thing to bend was pushrods. I might be a little worried about the rest of that engine rebuild though, like bearing clearances and such. Like you said shawty, time will tell.
  20. #20 Re: cranks no start
    brunswick
    now the dots are aligned they never met when i took this pic... and yea i got a few spares... i was rushing when i put it together...
  1. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  2. 2000 GTP cranks but will not start
    By darman1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2013, 01:46 PM
  3. Cranks but doesn't start sometime. Help!
    By Fluid604 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:59 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
