Thread: cranks no start
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 cranks no start
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Rebuilt engine.. car turns over but won't catch has fuel but no spark from coils..... coils tested good icm tested good new crank sensor....
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  2. #2 Re: cranks no start
    St. Louis
    Check all the fuses (underhood and in-car)? Attach the ground for the ICM?
  3. #3 Re: cranks no start
    brunswick
    Every ign fuse checked and grounded to stud for head
  4. #4 Re: cranks no start
    pop a plug wire off the coil and prop it a inch over the coil where it plugs on, then crank the car, your looking for a spark to jump to the wire from the coil.
  5. #5 Re: cranks no start
    brunswick
    No coil is giving off a spark I have a tester that I plug on coil and plug wire not showing any spark... put testr on another car it works fine
  6. #6 Re: cranks no start
    the crank sensor and cam harness look ok? maybe try swapping the icm they test good and are bad some times.
  7. #7 Re: cranks no start
    Wrong plug routing?
  8. #8 Re: cranks no start
    brunswick
    The plug wires are right and harness is fine as it appears and has power 12v to pink wire
  9. #9 Re: cranks no start
    icm ground is bolted on right?
  10. #10 Re: cranks no start
    brunswick
    YeS
  11. #11 Re: cranks no start
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    hook a jumper cable to the battery neg- post and to the alternator bracket see what happens. Has to be a bad ground somewhere.
  12. #12 Re: cranks no start
    brunswick
    Everything works crept spark
  13. #13 Re: cranks no start
    brunswick
    Hellppppppp
  14. #14 Re: cranks no start
    Connect the two small ground wires to the bolt at the trans where you connect the main ground.
  15. #15 Re: cranks no start
    brunswick
    They are there I checked them first they are grounded should I replace can sensor
  16. #16 Re: cranks no start
    brunswick
    Cam magnet is there all grounds were checked multiple times no spark from coils pink wire has 12 volts any fuse or something that controls spark....
  17. #17 Re: cranks no start
    Is the ICM connector and the connectors at the pcm snug?
    I assume you changed the motor? So then we know it's likely something that was missed when you swapped. It's common and definately you will never forget what it was when it's found.
    Did you pull the wiring harness out with the motor or leave it in the engine bay?
  18. #18 Re: cranks no start
    brunswick
    left main wiring in car.. pulled mini harness with icm and yes its tight
  19. #19 Re: cranks no start
    Then you didn't disconnect the harness from the pcm?
    And you didn't disconnect the harness at the fuse box?
    Have you pulled plugs and found them wet?
    If you have no spark and prime 3 or so times, your plugs should show signs of wetness.
  20. #20 Re: cranks no start
    Pennsylvania
    I am no pro, but make sure to check for Cam and Crank signals both into and out of the ICM. If the PCM never gets the message its probably a bad ICM. I agree with everyone though, check the grounds...and then recheck.
  1. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  2. 2000 GTP cranks but will not start
    By darman1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2013, 01:46 PM
  3. Cranks but doesn't start sometime. Help!
    By Fluid604 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:59 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
