Thread: Crankshaft machining question
Results 1 to 10 of 10
  1. #1 Crankshaft machining question
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I have my GTP's bottom end in the machine shop, and my rod journals will have to be turned 20 thousandths due to my number 1 and 2 cylinders spinning rod bearings.I have heard the cranks have an issue being turned down,any truth to that?
    Basically, should i buy a new crank,or will my original be fine to get turned.
    Mods will be new federal mogul speed pro pistons (factory compression) ,L32 rods,ARP main and rod bolts (both mains and rods will be machined for those bolts),balanced rotating assembly, XP cam,3.2-3.0 pully gen 3 and supporting stuff.
    Any advice would be greatly appreciated,thnx.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  2. #2 Re: Crankshaft machining question
    hangover park IL
    beware "new" cranks...many are welded and reground cranks that will break, seen it twice right at the journal shoulder....
    you will want a good used crank with minimal scoring...
    also have em check the oil pump recess in the front timing cover...since it ate itself id bet the aluminum cover is ****ed and even a new pump scroll and cover wont bring clearance into spec...so you need a good cover too...
    basically you need to buy a good motor before ever rebuilding a 3800 lol
    Moradparts.com is one of your best bets...i only have two minty used cranks and im saving em lol
    ~James~ Psychotic Gearhead
  3. #3 Re: Crankshaft machining question
    redneck tennessee
    Thanks for the info on the oilpump.Heres another question,Im going to get an oil pressure sender so i can actually tell whats going on pressure wise, what would a normal L67 run pressure wise?
  4. #4 Re: Crankshaft machining question
    hangover park IL
    35-40+ hot idle dep on yer oil visc
    a high idle should put you over 60
  5. #5 Re: Crankshaft machining question
    hangover park IL
    just beware that not many people have great luck with rebuilds...only a handfull of us seem to be able to pull it off.
    btw stay away from trimetal bearings, use and size everything for the OEM aluminum babbit bearings
  6. #6 Re: Crankshaft machining question
    redneck tennessee
    Ok, at least i will know the range i should have.On the crank tho, yey or neh on turning it?Would it have strength or smoothness issues from being turned?
  7. #7 Re: Crankshaft machining question
    hangover park IL
    our crank is already weak because of the split journals...by removing 20 thou from both journals you are weakening it even further... I would not suggest it but for a bone stocker it might be fine....but stay away from welded and re ground crankshafts.
    its real s***** to destroy a bunch of parts and time from skimping on one component
  8. #8 Re: Crankshaft machining question
    HUDSON
    A few things should be known about building engines to be a success, it's not about luck, it's not hit-or miss either, it is about paying attention to detail and the basic knowledge of engine theory that will be the deciding factor between "YAY", or "NAY". Knowledge is power, and that knowledge can directly relate to power put down to the pavement. Know what your clearances should be, and check them, if they are not correct, make them correct. Make sure the everything is straight, true, and square, if it is not, make it straight, true, and square. Know what you are working with, if you don't know, learn. If you don't want to learn, don't do it. Make it 100%, or don't make it at all or you will look foolish with parts bouncing off the pavement surface. Oil bearing clearances, machine finish surfacing, side clearances, piston ring clearance, torque spec and sequence. Become friends with your local machinist if you have one in your town.
  9. #9 Re: Crankshaft machining question
    I'm surprised James didn't mention the oiling deficiences.
  10. #10 Re: Crankshaft machining question
    hangover park IL
    there's those but aside from making sure the oil passages are cleaned up in the bad spots and deleting the filter bypass most of my mods are to better control oil return and windage....moar pah
  1. Machining RM Double Roller?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2014, 08:09 AM
  2. Machining Supercharger Snout?
    By transam24 in forum General Tech Discussion
    Last Post: 11-19-2013, 06:33 AM
  3. Machining LIM & S/C????
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2009, 06:35 PM
  4. machining
    By gotboost3 in forum Tires & Wheels
    Last Post: 07-30-2009, 09:26 PM
  5. Machining LIM
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2008, 11:45 AM
