Thread: To lq4 or to not lq4 that is the question
Results 1 to 8 of 8
  1. #1 To lq4 or to not lq4 that is the question
    SE Level Member Sevex's Avatar
    Aug 2012
    Utah
    Alright I have an 04 comp g that I am collecting parts for, I plan on doing everything at on e and would like to get all the info I need up front. After doing some searching I have read a lot of mixed reviews on if I should run an LQ4 MAF with my setup or just run the stocker, some people have said stock will flow just fine and some say go lq4?
    My mod list is as follows
    SD headers
    phenolic stage 2 intercooler
    1.9 roller rockers
    180 t-stat
    al103's
    42.5's if needed (will run stockers till they max out)
    i have a 4" intake and k&n waiting to go on
    i also plan on running a 3.1 or 3.0 pulley if I can, I have a 3.2 and a 2.9 also but I don't think I can get away with the 2.9
    Blower will be ported, all the little supporting mods will be done and all tuned with hptuners for 92 octane
    so my question is with this setup should I worry about the lq4 or just leave the stocker? I only wanna build the intake once and only wanna order the couplers for one MAF. And if I do run the lq4 what tables are you using? The ones off ZZP's website close?
    Thanks
    colt
    04 CompG, 1.9 rr, 90# springs, modded SD headers, 42.5#.... intercooler/3.0 mps coming soon.
  2. #2 Re: To lq4 or to not lq4 that is the question
    Below a 3.4 your going to probably starting out flowing the maf so that would be when you would want to upgrade
    04 Comp G.
  3. #3 Re: To lq4 or to not lq4 that is the question
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    why port the Gen V?
  4. #4 Re: To lq4 or to not lq4 that is the question
    Aug 2012
    Utah
    Not really ported, the inlet side will be cleaned up and polished and just a small cleanup on the outlet. I guess I should just do the LQ4 when the intercooler goes on
  5. #5 Re: To lq4 or to not lq4 that is the question
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Correct, I typically recommend a MAF upgrade at a 3.4 pulley and injectors below a 3.4 pulley, so you'll need both.
    I sell a MAF upgrade now on my website, and injectors.
    Email all inquiries to willoverkill@gmail.com!
  6. #6 Re: To lq4 or to not lq4 that is the question
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by Overkill View Post
    Great new site Will some good info and good products as well!
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  7. #7 Re: To lq4 or to not lq4 that is the question
    Aug 2012
    Utah
    I currently have an lq4 MAF and a full set of 42.5's here at the house, I just didn't know if I should do the MAF and injectors when I do the intercooler. I just a little nervous doing everything all at once then trying to tune it all out with new MAF and injectors and a smaller pulley all at once.
  8. #8 Re: To lq4 or to not lq4 that is the question
    Quote Originally Posted by timboku View Post
    Cheers!
    You could always install the maf, tune it, then injectors, tune it, then the IC with smaller pulley. If you have HP Tuners, there's always avenues for getting tuning help, I can offer my services if it's too much to tackle on your own.
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
