Thread: cone filter
Results 1 to 4 of 4
  1. #1 cone filter
    Aug 2013
    ny
    Ok question. We all know the cone filter on stock gtp makes the sc whine louder and noticable. Well my problem is I just unhoocked the intake from the air box and put on the cone filter on stock tubing (end of intake faces radiator hose) and I hear no difference ! Should it? Or do I need to get coupler and 30 deg elbow and make the filter by the tb
  2. #2 Re: cone filter
    Aug 2013
    ny
    !!!edit. Make the filter closer to the tb
  3. #3 Re: cone filter
    What are you driving? You should hear a big difference
  4. #4 Re: cone filter
    Omaha, NE
    The problem is that you're using the stock intake tube. You probably have a leak past the filter, and the stock tubing creates air turbulance.
    Your best bet at this point is to put your stock intake back together until you figure out what you're doing.
  1. Cone filter on TB??
    By mickey t in forum General Tech Discussion
    Last Post: 06-13-2009, 07:45 PM
  2. cone filter size
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2009, 12:51 AM
  3. cone filter on the tb trick
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-14-2009, 11:33 PM
  4. Amsoil Cone Filter
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2008, 10:09 AM
