Thread: cone filter on the tb trick
Results 1 to 20 of 20
pontiacGTP123 cone filter on the tb trick 05-13-2009, 11:10 AM
Guest Re: cone filter on the tb... 05-13-2009, 11:22 AM
pontiacGTP123 Re: cone filter on the tb... 05-13-2009, 11:25 AM
Guest Re: cone filter on the tb... 05-13-2009, 11:36 AM
Bio248 Re: cone filter on the tb... 05-13-2009, 12:50 PM
blueguy Re: cone filter on the tb... 05-13-2009, 01:58 PM
gotboost3 Re: cone filter on the tb... 05-14-2009, 02:08 AM
blueguy Re: cone filter on the tb... 05-14-2009, 11:19 AM
Bio248 Re: cone filter on the tb... 05-14-2009, 01:40 PM
gixer2000 Re: cone filter on the tb... 05-14-2009, 01:45 PM
Bio248 Re: cone filter on the tb... 05-14-2009, 02:08 PM
blueguy Re: cone filter on the tb... 05-14-2009, 02:10 PM
Bio248 Re: cone filter on the tb... 05-14-2009, 02:12 PM
NewImage Re: cone filter on the tb... 05-14-2009, 02:25 PM
blueguy Re: cone filter on the tb... 05-14-2009, 02:27 PM
blueguy Re: cone filter on the tb... 05-14-2009, 02:20 PM
Bio248 Re: cone filter on the tb... 05-14-2009, 06:52 PM
Iron Indian Re: cone filter on the tb... 05-14-2009, 09:59 PM
Bio248 Re: cone filter on the tb... 05-14-2009, 10:11 PM
blueguy Re: cone filter on the tb... 05-14-2009, 11:33 PM
  1. #1 cone filter on the tb trick
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    Well Im kinda short on $ and want to be able to throw out the k&n drop in filter and clamp a cone filter to the tb, I have heard of this before and was wondering how safe and effective this mod is, would it be a good idea overall to just remove the tubing from the stock air box and leave it with my pcm, and filter and just clamp the cone on?
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  2. #2 Re: cone filter on the tb trick
    TDCRacing
    Guest
    Sure you can do that. You can put a cone on the TB. The size of the TB is 3.75 inches.
  3. #3 Re: cone filter on the tb trick
    stanford Ky
    thanks.
    99 gtp- sold
  4. #4 Re: cone filter on the tb trick
    TDCRacing
    Guest
    No problem.
  5. #5 Re: cone filter on the tb trick
    you can do it but with your limited amount of modding it might not be the best intake.
    your blower whine will definitely be a lot louder though. i love my open cone.
  6. #6 Re: cone filter on the tb trick
    X2...it's better than a stock box but probably not as good as a FWI for your car that is basically stock
  7. #7 Re: cone filter on the tb trick
    Donating Users
    Plainfield, IL
    yeah the only time ill ever go open cone is if i got IC'ed
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  8. #8 Re: cone filter on the tb trick
    Quote Originally Posted by gotboost3 View Post
    You'd do it with a 3.2" setup...like a cam or Meth
  9. #9 Re: cone filter on the tb trick
    id do it on any setup since im a jackass like that, but it really becomes effective when you get past the basic 3.4 setup.
  10. #10 Re: cone filter on the tb trick
    SE Level Member gixer2000's Avatar
    Braintree, ma
    you will pick up a lot of heat from the exhaust crossover that will be right below it.
  11. #11 Re: cone filter on the tb trick
    Quote Originally Posted by gixer2000 View Post
    doesnt matter if youre intercooled or running a smaller pulley than a 3.4 or so. having low IATs is not really that big of a deal once youre decently modded. anyone that says "the coldest air possible, regardless of bends" is a moron, straight up. around the 3.2 pulley range, flow helps more than anything. i bet if i had an FWI right now and switched to an open cone i would pick up 5-8 whp, if not more.
  12. #12 Re: cone filter on the tb trick
    I know for sure if not actual HP gains you get a **** ton better throttle response and all you hear is that damn blower whining twice as loud
  13. #13 Re: cone filter on the tb trick
    that is why i will forever and always say that an FWI is only a good mod for a lightly to moderately modded car. anything past that should skip the piping and shove the cone on the throttle body.
  14. #14 Re: cone filter on the tb trick
    SE Level Member NewImage's Avatar
    Cadillac, MI
    where the heck do you put the IAT sensor if you go this route?
    1998 Daytona 500 GTP #962/1500
    2003 Atlantic Blue Dodge Ram QC/SB
    My Past and Present Vehicles: http://www.cardomain.com/id/SolScuba
  15. #15 Re: cone filter on the tb trick
    Quote Originally Posted by NewImage View Post
    I stuck mine in there...just kinda let it hang out.
  16. #16 Re: cone filter on the tb trick
    Plus it makes **** easier to work on to...you dont have to **** with an intake system you can just yank it all out at once
  17. #17 Re: cone filter on the tb trick
    i zip tied mine to all the wires hanging out around my throttle body. all it needs to be is near the cone.
  18. #18 Re: cone filter on the tb trick
    Moore, Oklahoma
    Disable the IAT and use it for a happy knob (timing adjuster) like I did....
    Shawn W. Larsen
  19. #19 Re: cone filter on the tb trick
    Quote Originally Posted by Iron Indian View Post
    that is the LAST thing i need to do to finish my setup before i switch over to e85. then i can command whatever timing lets me run knock free on any random day of the week. cant wait. already have the parts, just need the tune for it.
  20. #20 Re: cone filter on the tb trick
    Get R done
  1. July 17 - Tinley Park, IL - Def Leppard, Poison, Cheap Trick
    By FastKatt in forum Shows and Events
    Last Post: 04-08-2009, 12:47 PM
  2. Amsoil Cone Filter
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2008, 10:09 AM
  3. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
