Thread: Random no start- flooded?
Results 1 to 6 of 6
  1. #1 Random no start- flooded?
    Jun 2010
    Bakersfield, CA
    About once in every 100 starts, my 2000 gtp fails to start after the first turn of the key. After that, it will not start.... Just crank & crank... Acting like it is flooded. If i let it sit for 10 minutes or so, it will start right up. Any suggestions?
    Sent from my DROID RAZR using Tapatalk 2
  2. #2 Re: Random no start- flooded?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Do you hear the fuel pump during the no start conditions? My GT used to do that except more often, turned out to be the fuel pressure regulator. Take the vac line off of the top of your regulator and let it run for 5 minutes or so and see if any fuel seeps out of top of the regulator, if so replace it.
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  3. #3 Re: Random no start- flooded?
    Jun 2010
    Bakersfield, CA
    Popped off the line to the fuel pressure regulator. It was dry. The rubber connector has a crack in it. I don't think that would cause it, but i will fix that.
    The fuel pump primes when the key turns on. Just seems to flood if i don't get it to start in the first try.
  4. #4 Re: Random no start- flooded?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    If it actually is flooded, mash the pedal all the way to the ground and start cranking the car.
    This puts the car in clear flood mode. It shouldn't start - or easily at least, but do this a couple times and it should clear the cylinders up.
  5. #5 Re: Random no start- flooded?
    Jun 2010
    Bakersfield, CA
    So this issue is down to about once in every 30 starts. There is just simply no ignition. If i keep cranking, it will not start ever... Just crank & crank with no attempt at ignition. If i don't keep cranking i can wait two minutes and try again and it will fire. No idea where to even start to diagnose the issue.
  6. #6 Re: Random no start- flooded?
    St. Louis
    When it pulls the no start issue, check for spark. Sounds like maybe the ICM is doing something wierd.
  1. Flooded Floorboard ***Deflector Installed***
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 07-23-2012, 05:08 PM
  2. 93 Mold's 88 Random no start
    By acidcrashdburnd in forum Other Vehicles
    Last Post: 07-05-2012, 10:08 AM
  3. 3.8L SC Random stalls, faulty intermittent start!
    By agentbluescreen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 01:22 PM
  4. Flooded with Salt water
    By Scott B in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2009, 03:56 PM
  5. Flooded Basement
    By Deezul_AwT in forum The Rant Forum
    Last Post: 05-15-2008, 05:52 AM
