Thread: Modded fuel rails leaking and engine knocking when mashing the gas
Results 1 to 20 of 40
  1. #1 Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Ok guys 97 gtp here's the problem: drove the car yesterday and every time I put my foot on the gas my KR climbed higher and higher so that scared me a little... i have engine vibration but that might be from the exhaust not all the way bolt to the resonator could that be setting false knock? Changed the oil once after everything was put back together do I need to do another oil change? Also modded fuel rails leak where the brass lines connect from both sides.. I changed the O Rings still nuthin any suggestions? Thanks guys!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Did you use teflon tape on the threads before you tightened it down?
  3. #3 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Teflon tape? For what?
  4. #4 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Mar 2012
    NC
    I'm pretty sure I warned you about this...not to rub it in...but yeah, I guess I am. Double check the fittings on the fuel rail. If using compression fittings, make sure you cranked the hell out of them.
  5. #5 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Sven Sexman View Post
    Why are you putting me down man lol i'll check what would you use to crank them with?
  6. #6 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Mar 2012
    NC
    I would use a typical tubing wrench...just tighten then as tight as you possibly can.
  7. #7 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Ok I just dont want to f**k the thread up or strip it coul you give some insight on why the KR climbs when I put foot on the gas?
  8. #8 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Mar 2012
    NC
    Well, the KR climbing could still be fuel related or tune related or whatever. I didn't follow the build thread in depth, but I'll skim through it and see what I come up with. Maybe there's something that was missed.
  9. #9 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    May 2008
    Schuyler, NE
    What fuel rails do you have?
    Tightening them as much as you can, makes me cringe.
  10. #10 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Gtp power I have zzp modded fuel rails
  11. #11 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Teflon tape where the braided line hooks up to the rail
  12. #12 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    May 2008
    Schuyler, NE
    What fittings are on the braided hose?
  13. #13 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    gardner,mass
    I wouldnt be driving it with leaking fuel.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  14. #14 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Ok i'll do that
    I guess the ones that come with rails which ones do you mean? There are different types of fittings?
  15. #15 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Quote Originally Posted by Ginseng View Post
    Agreed, I hope you keep a fire extinguisher around.
    You shouldn't need Teflon tape for those compression fittings, ensure that the surfaces are clean and undamaged, you may just need a new braided hose
    Email all inquiries to willoverkill@gmail.com!
  16. #16 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Overkill View Post
    Im not driving the car as of now being I just found the problem... I have 2 braided hoses but one is smaller and wont fit over the blower I might have grab a new one like so though overkill I know you do countless tunes for our motors could this be why KR climbs when I put my foot on gas just to accelerate?
  17. #17 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    These are the braided lines im using..
  18. #18 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    May 2008
    Schuyler, NE
    Are those AN fittings?
  19. #19 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Banned
    Jan 2013
    maryland
    Am I supposed to use the gold looking fittings? I noticed a lot of guys using the gold ones are those the ones that need to be used
  20. #20 Re: Modded fuel rails leaking and engine knocking when mashing the gas
    Florida
    How high a KR are you seeing and what size injectors and pulley are you running??
    You shouldn't need to use teflon tape on them, but they shouldn't be leaking. I'd take the braided line off, clean all the fittings really well, wrap the male fittings with a little teflon tape, and reinstall. Mine I go until they are snug, then just a little bump, never once had a leak.
    Those IC lines aren't being pinched ontop of the coil pack are they? First spin I took after my IC install, I hadn't purged all the air out of the IC so it was basically useless. Saw 13* of knock on part throttle. Purged all the air, now I'm seeing 0.
  1. Modded fuel rails and engine cover?
    By txslow6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2012, 10:16 AM
  2. L67 modded fuel rails
    By txslow6 in forum Wanted To Buy - Parts
    Last Post: 02-25-2012, 09:38 AM
  3. WTB: Modded fuel rails for 01 gtp
    By samuelcb409 in forum Wanted To Buy - Parts
    Last Post: 02-09-2012, 07:31 PM
  4. modded fuel rails
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2011, 10:56 PM
