This is the second time I have replaced this gasket. Both are felpro. I sprayed carb cleaner and found a leak under the supercharger around the thermostat housing. So I replaced the gasket and its still leaking so I removed it and put a bead of silicone around the whole gasket, top and bottom. Waited a couple days for it to dry and it still leaks from that same spot. Got a new gasket and checked both mating surfaces with a square and no light comes through. I took 2000 grit sandpaper and wet sanded to remove any corrosion as it looks like its been leaking a while and its still leaking not as bad though.. I torqued the supercharger to 17ft/lbs. Any suggestions?
