Thread: 3800sc upper plenum leak
Results 1 to 7 of 7
  1. #1 Re: 3800sc upper plenum leak
    people do it all the time with ic installs. sounds odd that it would still leak with the gasket rtv'ed. that should have done it.
    unless its a injector o ring sicking in the carb cleaner? or the boost by pass solenoid?
    maybe smoke test it. then you'll know for sure.
  2. #2 Re: 3800sc upper plenum leak
    Aug 2013
    Kitimat, B.C.
    Yeah I figured the gasket and rtv woulda sealed it up tight. Weird thing is I'm getting no smoke out that spot or bubbles from a soapy water solution. Only the carb cleaner makes it stumble, although this time it's not as bad all from the same spot.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  1. Reuse L36 upper plenum gasket?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2012, 08:19 PM
  2. upper intake plenum
    By 94grandprix in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-21-2011, 03:55 PM
  3. Upper Plenum
    By chev1988rolet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2010, 08:16 AM
  4. Where can I buy Upper Intake Plenum?
    By dgiles79 in forum Shops and Community Heroes
    Last Post: 09-20-2009, 10:29 PM
