Thread: horn doesn't work
Results 1 to 20 of 29
  1. #1 horn doesn't work
    GT Level Member m17davis's Avatar
    Orland Park, IL
    so ive seen every thread on here. I hotwired the horn and it worked. I replaced the blown fuse. I checked the ground under the airbag and it looks fine. idk what to do.. please help. is there supposed to be a nut on this?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: horn doesn't work
    Orland Park, IL
    just came across something strange. when I was wiggling out the 4 prong fuse under the hood the horn went off. it happened when I tilted it upwards...
  3. #3 Re: horn doesn't work
    Orland Park, IL
    I also found this. is it important?
  4. #4 Re: horn doesn't work
    Orland Park, IL
  5. #5 Re: horn doesn't work
    Dec 2012
    Where 4T65E's were born
    Well now you know the issue if from the b+ wire that activates the horn relay, from the steering wheel to the power distribution box. Did you ever see if that wire that's broken is the wire you're looking for? Check to make sure there's no voltage there then check resistance. Should get the resistance of a relay, if so solder it to where it should be. If not find the horn wire and make sure it's intact.
    Sold.
  6. #6 Re: horn doesn't work
    does your air bag have 2 wires coming out of it? one is the push in and turn to lock it in the whole. the other the black one has a clip in the end, it fits on the treads sticking out of the steering wheel.
  7. #7 Re: horn doesn't work
    Orland Park, IL
    Just found out that the wire in that picture is for my remote start. dam. How do I find the horn wire
  8. #8 Re: horn doesn't work
    Orland Park, IL
    there are only 2 wires. one is black and one is yellow. haha black and yellow...
  9. #9 Re: horn doesn't work
    the yellow wire in the middle is the air bag to clock spring, the other black wire next to the yellow wire is the radio controls.
    that black wire looks wrong to me. (clipped to the air bag) you need two wires out of the air bag. the push in and turn one there thats power, not the ground.
    at least on my car.
    i bet if you take that wire off the air bag, the black one, and then ground it. the horn beeps. thats after you change the fuse again, cause that would explain the blown fuse.
  10. #10 Re: horn doesn't work
    Orland Park, IL
    yeah. that black wire that is clipped to the airbag goes in that hole and it feels like there is a spring attached to it cause I can pull on it and let go and it gets pulled back in. where do you think I should ground it?
  11. #11 Re: horn doesn't work
    found this pic of one for sale seems to only have the one wire too. very odd.
  12. #12 Re: horn doesn't work
    Orland Park, IL
    Bob Saget! I always have strange problems with my car!
  13. #13 Re: horn doesn't work
    some how i bet the horn button is bad or a bad contact in the air bag cover, it should come off with them clips on the 4 sides.
  14. #14 Re: horn doesn't work
    Orland Park, IL
    should I try to ground it somewhere else?
  15. #15 Re: horn doesn't work
    yeah. i would, take the wire off the bag, then ground it on the column. if it beeps the horn button or its contacts are bad.
    come to think of it, my friends Chevy truck horn would work when it felt like, i took the air bag off and cleaned where the bag hit the column and the horn worked perfect again.
  16. #16 Re: horn doesn't work
    Orland Park, IL
    my horn hasnt worked in 6 years. I cleaned it and grounded it somewhere else. And nothing. fuse and relay are good
  17. #17 Re: horn doesn't work
    gremlins suck. sorry im out of ideas. you need some one with a multi tool that knows how to use it. shorts are easy to find if you know how to find them.
  18. #18 Re: horn doesn't work
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Had a similar problem like this in my 95 Buick. Ran a wire from battery to horn with an inline fuse. Then a ground with a push button, mounted between the steering wheel and radio.. Worked great
    Sent from my Lumia 900 using Board Express
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  19. #19 Re: horn doesn't work
    Orland Park, IL
  20. #20 Re: horn doesn't work
    time to run that new wire all nice like. nice find.
    so there must be a bad wire somewhere in the harness.
    at least you can stop yelling out the window at morons on the road now lol
  1. How can you make the horn work with the key fob?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 12:51 PM
  2. Airbag light, wheel controls, horn doesn't work.
    By buck531 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2012, 06:11 PM
  3. Horn doesn't work, any help?
    By hockeybawler in forum General Tech Discussion
    Last Post: 10-10-2012, 10:30 PM
  4. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  5. Help! My horn doesnt work...
    By 97gtpprix in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2010, 04:08 PM
