Thread: horn doesn't work
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: horn doesn't work
    GT Level Member m17davis's Avatar
    Orland Park, IL
    the bad wire is between the fuse boxes somewhere....lol I don't waste my time yelling. I just put in neutral and rev the **** out of it. they get the picture. Thanks for all your help. once again.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: horn doesn't work
    theres a harness under the fuse box that runs into the cab along the sub frame. maybe you can snake that new wire through there. it comes in the car by the fan
  3. #3 Re: horn doesn't work
    Feb 2013
    37.295091, -121.930053
    also put your own fuse in it, just in case it wont stop making sound.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: horn doesn't work
    i bet if he pulled the fuse it would stop working. he just by passed some of the stock harness.
  5. #5 Re: horn doesn't work
    Orland Park, IL
    yupp. I just ran a wire right next to the other ones through the firewall. therefore its virtually the same thing. the fuse will stil work.
  6. #6 Re: horn doesn't work
    beep beep, beep beep yeah!
  7. #7 Re: horn doesn't work
    Feb 2013
    Scotty the only reason I suggested it is if it fails and honks on its own he should have a way of stoping it quickly
  8. #8 Re: horn doesn't work
    you and your fuse lol cut the brown wire!!!!
  9. #9 Re: horn doesn't work
    Feb 2013
    Nooooo it will blow up!!!!!!
  1. How can you make the horn work with the key fob?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-08-2012, 12:51 PM
  2. Airbag light, wheel controls, horn doesn't work.
    By buck531 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2012, 06:11 PM
  3. Horn doesn't work, any help?
    By hockeybawler in forum General Tech Discussion
    Last Post: 10-10-2012, 10:30 PM
  4. FAQ doesn't work
    By Jakescoots in forum Forum Bugs/Suggestions
    Last Post: 04-23-2011, 10:41 AM
  5. Help! My horn doesnt work...
    By 97gtpprix in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2010, 04:08 PM
