the bad wire is between the fuse boxes somewhere....lol I don't waste my time yelling. I just put in neutral and rev the **** out of it. they get the picture. Thanks for all your help. once again.
theres a harness under the fuse box that runs into the cab along the sub frame. maybe you can snake that new wire through there. it comes in the car by the fan
also put your own fuse in it, just in case it wont stop making sound.
yupp. I just ran a wire right next to the other ones through the firewall. therefore its virtually the same thing. the fuse will stil work. :)
beep beep, beep beep yeah!
Scotty the only reason I suggested it is if it fails and honks on its own he should have a way of stoping it quickly
Nooooo it will blow up!!!!!!
