Quote Originally Posted by Steven Monteith View Post
What causes crankcase pressure?
The normal operation of the internal combustion engine.
If you let the motor run for a minute, then remove the oil cap, can you hear/feel pressure being released?
If so, more than likely the PCV has taken a dump, quick easy fix fix. Pop the 2 bolts off, swap it out, and then repeat the above test.
