Thread: Loud whine in engine bay
Results 1 to 14 of 14
OZZY1123 Loud whine in engine bay 01-07-2014, 12:40 AM
Fivefingerdeathpunch Re: Power Steering Whine? 01-07-2014, 12:47 AM
OZZY1123 Re: Power Steering Whine? 01-07-2014, 01:20 AM
ChrisL Re: Power Steering Whine? 01-07-2014, 10:51 AM
OZZY1123 Re: Power Steering Whine? 01-08-2014, 01:32 AM
l67ss Re: Loud whine in engine bay 01-08-2014, 02:37 AM
RegalGS98s Re: Loud whine in engine bay 01-08-2014, 06:28 AM
OZZY1123 Re: Loud whine in engine bay 01-08-2014, 09:24 PM
REDCRAPGP Re: Loud whine in engine bay 01-08-2014, 09:27 PM
OZZY1123 Re: Loud whine in engine bay 01-08-2014, 09:34 PM
RegalGS98s Re: Loud whine in engine bay 01-09-2014, 08:46 AM
OZZY1123 Re: Loud whine in engine bay 01-09-2014, 03:58 PM
OZZY1123 Re: Loud whine in engine bay 01-09-2014, 11:02 PM
RegalGS98s Re: Loud whine in engine bay 01-10-2014, 06:30 AM
  1. #1 Loud whine in engine bay
    SE Level Member OZZY1123's Avatar
    Jan 2013
    Red Deer Alberta, Canada
    Hey guys, for about 4 or 5 weeks now my car has been making a terrible whining noise coming from up front passenger side. Just thought it was probably low on steering fluid so topped it up and still making noises. Anyone know of a cheap fix or am I looking at new parts?
  2. #2 Re: Power Steering Whine?
    Double check your trans fluid level, it can make the same sound.
    If that checks out, it might be he pump dying.
  3. #3 Re: Power Steering Whine?
    Jan 2013
    Trans fluid normal, power steering fluid normal, sound is only present until about ~3000rpm then goes away and stops after being warm for a few minutes, does not change when wheel is turned and only comes back when slowing down and getting into that rev range again
  4. #4 Re: Power Steering Whine?
    Oct 2013
    NC
    How old is the power steering fluid? I replaced my old thick fluid out using a spray bottle and that made a big difference.
  5. #5 Re: Power Steering Whine?
    Jan 2013
    I'll maybe give that a go.. I'm not sure if that's it though because the noise does not change when the wheel is turned. Could it be belts rubbing or bearings going somewhere?
  6. #6 Re: Loud whine in engine bay
    Dec 2012
    troll land
    If its the ps pump dying a lotta times the sound wont change. Also check for kinked ps lines(ie caused by mebbe a callapsed mount?)
  7. #7 Re: Loud whine in engine bay
    GT Level Member RegalGS98s's Avatar
    NJ
    Sure it's not the supercharger you hear whining? Take the belt off and start the car to see if the whining goes away. Just don't rev it crazy like that. Then if you still hear it, take the serpentine belt off also and start the car to see if the whine is still present. If you still hear it, then likely the transmission. If it is powersteering, I think it was bars powersteering fix I used on the last powersteering problem I had. It's a 2 part separated bottle for about $9 at walmart. If that doesn't do it, then likely powersteering pump and/ or steering rack. Could also be the suction low pressure side of the powersteering hose could have a leak just enough to suck in air, but not leak fluid out.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  8. #8 Re: Loud whine in engine bay
    Jan 2013
    Belts off made noise go away, now to pinpoint which one it is.. any ideas?
  9. #9 Re: Loud whine in engine bay
    How old is the belt?
    04 Comp G.
  10. #10 Re: Loud whine in engine bay
    Jan 2013
    It's on the belt with supercharger on it. One idler is a bit loose and wobbly and the other has a chip out of it. am I right in suspecting the wobbly one? Where's my best bet to buy a new one?
  11. #11 Re: Loud whine in engine bay
    NJ
    Quote Originally Posted by OZZY1123 View Post
    Usually the 3 inch pulley goes bad and the 3.5 is ok. After replacing the 3 inch one 3 times, I changed both of mine to the 3.5 and haven't had to change them since. It's a tight fit, but makes the belt a bit tighter too so it doesn't slip on the supercharger. I get mine from Rockauto if you can wait, or any of the parts stores if you need it then. I've had better luck with the metal pulleys than the plastic ones.
  12. #12 Re: Loud whine in engine bay
    Jan 2013
    Picked up a 3.5 from the wreckers, should last me a little while at least. Big thanks to gm for putting a torx bolt down there
  13. #13 Re: Loud whine in engine bay
    Jan 2013
    Fixed! Thanks for the help guys
  14. #14 Re: Loud whine in engine bay
    NJ
    Np dude, glad it was something simple and cheap.
  1. power steering whine
    By Orange04CompG in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 11:30 AM
  2. Power Steering whine
    By nickgpgt in forum General Tech Discussion
    Last Post: 05-26-2013, 07:38 PM
  3. power steering whine?
    By Garrett Mofford in forum General Tech Discussion
    Last Post: 10-19-2012, 04:37 PM
  4. power steering whine on turns
    By Warbeaver in forum General Tech Discussion
    Last Post: 06-04-2010, 08:21 AM
  5. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
