Thread: Loud whine in engine bay
Results 1 to 14 of 14
  1. #1 Re: Loud whine in engine bay
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by OZZY1123 View Post
    It's on the belt with supercharger on it. One idler is a bit loose and wobbly and the other has a chip out of it. am I right in suspecting the wobbly one? Where's my best bet to buy a new one?
    Usually the 3 inch pulley goes bad and the 3.5 is ok. After replacing the 3 inch one 3 times, I changed both of mine to the 3.5 and haven't had to change them since. It's a tight fit, but makes the belt a bit tighter too so it doesn't slip on the supercharger. I get mine from Rockauto if you can wait, or any of the parts stores if you need it then. I've had better luck with the metal pulleys than the plastic ones.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. power steering whine
    By Orange04CompG in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 11:30 AM
  2. Power Steering whine
    By nickgpgt in forum General Tech Discussion
    Last Post: 05-26-2013, 07:38 PM
  3. power steering whine?
    By Garrett Mofford in forum General Tech Discussion
    Last Post: 10-19-2012, 04:37 PM
  4. power steering whine on turns
    By Warbeaver in forum General Tech Discussion
    Last Post: 06-04-2010, 08:21 AM
  5. Power steering whine on left turns only...
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 12:19 PM
