Thread: Vibration and shudder with lots of boost
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Vibration and shudder with lots of boost
    Oct 2013
    WI
    The plugs looked ok, but only pulled two of them, looked pretty clean and gap was still good. The 198K oil change was from the previous receipts, I've changed it since.
  2. #22 Re: Vibration and shudder with lots of boost
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    i use to have a similar problem as described and my problem ended up being the coil packs being needed to be replaced.
    chris
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #23 Re: Vibration and shudder with lots of boost
    Oct 2013
    WI
    I took out the MAF and cleaned it, it didn't look to dirty - I seem some people mention there's is "fuzzy". Can't test if it helped right now, bunch of snow on the roads
  4. #24 Re: Vibration and shudder with lots of boost
    is that before or after the maf cleaner? it looks a bit dirty. they should be sorta shinny looking.
  5. #25 Re: Vibration and shudder with lots of boost
    Oct 2013
    WI
    That was the before, the sensor didn't look a lot cleaner afterwards, still dull gray, though the two vertical bars it connects to got a lot shinier
  6. #26 Re: Vibration and shudder with lots of boost
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    That really sounds like a bad axle to me. If you have enough load/torque it will shutter and feel like it's coming from the engine.
  7. #27 Re: Vibration and shudder with lots of boost
    Oct 2013
    WI
    A quick follow-up, still have issues after cleaning the sensor, but I've since found the lower motor mount is destroyed - could that be causing the vibration under heavy load? Need to figure out how to strap a camera under the hood while driving to see
  8. #28 Re: Vibration and shudder with lots of boost
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    I have a 2000 SE 3.1. Mine would shutter taking off from a stop. As Chris said it turned out to be the coil pak. I checked the coils old school. Took a wire off 1 tower started it up no spark. Good. Took next wire off started it up spark flying all over the coil pak. Bad. Replaced them no more shutter. Did away with my random misfire code.
  9. #29 Re: Vibration and shudder with lots of boost
    Quote Originally Posted by jasonnovak View Post
    If its destroyed like you say it is, it's going to throw off the axle geometry. Just replace it and see what happens, because it's already shot.
  10. #30 Re: Vibration and shudder with lots of boost
    Mar 2012
    South Beloit, IL
    Oh my god, If your lower motor mount is shot, change that thing asap. Check the tranny mount too. I can't emphasize to you the problems I thought my car had before I changed a shot motor mount - night and day difference.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. transmission shudder
    By robopat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2013, 10:40 PM
  3. shudder under acceleration
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2012, 07:38 PM
  4. 94 3.1 shudder
    By stevirebel in forum Introductions/Noob Questions
    Last Post: 11-02-2009, 03:12 PM
