6/15/2012 |
198,057 |
Oil Change (inspection all passed) 5w30 |
3/20/2012 |
195,057 |
Replace FR Wheel bearing, real brake bad/rotors |
2/17/2012 |
194,299 |
Alternator (battery 2 yr old) |
7/15/2011 |
186,444 |
Traction Control C0035/C0036 Left Front Speed, sensor gooddamaged wire on left front wiring harness declined repair |
7/5/2011 |
186,158 |
Exhaust leak, installed 5in pipe 54-8518 |
6/17/2011 |
182,788 |
New Radiator hose Replace front brake pads/rotors/RF Caliper
Installed exhaust flex pipe/MAF sensor? |
6/8/2011 |
181,731 |
Radiator (1890) Aftermarket, not perfect fit |
4/27/2011 |
182,788 |
Replaced front tires |
3/25/2011 |
181,346 |
Left outer tierod, rf lower ball joint, front sway bar, left rear trailing arm |
4/13/2010 |
165,839 |
repaired radiator fan wiring |
9/23/2009 |
158,764 |
Replace both belts 12588411/12574914 |
6/2/2009 |
154,043 |
Overheats: Replaced lower intake manifold gaskets/related/thermostat |
6/21/2008 |
136,878 |
Recall/Left Valve cover gasket & wire retainer |
3/16/2008 |
~136000 |
Tie Rod/Front Left Hub/Left CV Shaft/Fuel Filter/Exhaust Gasket |
2/23/2007 |
130,845 |
New Transmission |
11/9/2006 |
126,000 |
Replace both swaybar links |
7/13/2006 |
Windshield |
