Thread: Felpro Head Gasket Question?
Results 1 to 5 of 5
  1. #1 Felpro Head Gasket Question?
    Daytona Beach, FL
    I have a set of head gaskets that are felpro and on both of the gaskets the direction arrow are pointing the same direction. They both have a R on them also, there is no L for Left! They are two of the exact same Gasket. When putting on the Right with the arrow pointing towards the pulleys seem fine, but when going to the Left side the arrow point towards the ballancer unless you flip it upside down! Has anyone had this problem before, any advice would be appreciated!
  2. #2 Re: Felpro Head Gasket Question?
    Daytona Beach, FL
  3. #3 Re: Felpro Head Gasket Question?
    Flip the gasket. Fel Pro only lists really one part number for an SC gasket. Point the arrow to the front and you are good.
  4. #4 Re: Felpro Head Gasket Question?
    Daytona Beach, FL
    Thanks for the the info Billboost! Its been driving me crazy trying to do this right! So facing the striped down on the one side on the block is the proper way to insall these? Just out of curiosity, what would happen if the arrow pointed towards the flywheel on that one side with the striping facing up? Thanks again for your input
  5. #5 Re: Felpro Head Gasket Question?
    Florida
    most likely the ports will not line up with the ports in the gasket.
  1. LIM-FelPro gasket failure?
    By michael redmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-10-2015, 05:11 AM
  2. WTS Felpro Head Bolt Set
    By Thompsju in forum For Sale - Parts
    Last Post: 10-27-2013, 12:32 AM
  3. Head Gasket Question
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 06:11 AM
  4. head gasket question
    By BLUESMOKEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2011, 08:57 AM
  5. LIM gasket - felpro or GM
    By cavGTP in forum 04+ Specifics
    Last Post: 12-03-2010, 12:30 PM
