Thread: Head Gasket Question
Results 1 to 12 of 12
  1. #1 Head Gasket Question
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    I finally got my gasket set in the mail today and noticed Felpro sent me graphite head gaskets, not metal...
    I have Permatex Ultra Copper silicone but not sure if I should use this with graphite gaskets??
    Thanks in advance for your help!
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Head Gasket Question
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Item # on gaskets?
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Head Gasket Question
    Oct 2012
    New Jersey
    Quote Originally Posted by bayus2972 View Post
    Item # on gaskets?
    FelPro - FelPro Head Gasket #FP-991-87-PT
  4. #4 Re: Head Gasket Question
    Minnesota
    Are you talking about lower intake gaskets not head gaskets? You want to use copper spray with head gaskets but you want to use the Ultra-gray RTV with LIM gaskets.
    You should get the Metal GM ones not the felpro gaskets.
  5. #5 Re: Head Gasket Question
    Oct 2012
    New Jersey
    Quote Originally Posted by Pure2sin View Post
    Funny thing is, the gaskets were graphite when I removed the heads. It must have came stock that way because I never touched them! Weird...
  6. #6 Re: Head Gasket Question
    Minnesota
    Quote Originally Posted by JerzNick View Post
    What I am trying to say is that their is no metal head gasket that I know of. They are come like the Felpro. Only the LIM gaskets come in metal.
    You don't use ultra copper silicone on them though. You would use copper spray like this:
    http://shop.zzperformance.com/store/...per-Spray.aspx
    I would get it from another place though.
  7. #7 Re: Head Gasket Question
    Jul 2012
    shouldn't need copper spray....just had mine replaced and I used the same gasket. Check the corner edge of the gasket, the mating surface should feel a little tacky.
  8. #8 Re: Head Gasket Question
    Minnesota
    You don't need it but it's extra insurance.
  9. #9 Re: Head Gasket Question
    Oct 2012
    New Jersey
    Great. Thanks again guys!
  10. #10 Re: Head Gasket Question
    Oct 2012
    New Jersey
    Thank you both for your input. Bayus2972: Will the copper spray hurt anything? or just not needed?
  11. #11 Re: Head Gasket Question
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    It won't hurt anything if anything it helps it seal better did mine last month and I put copper spray on em both sides.
  12. #12 Re: Head Gasket Question
    Right gaskets...and I always copper spray for the hell of it.
    On the metal gaskets. Sounds like the cometic mls gaskets. They are metal and do require spray.
  1. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. head gasket question
    By BLUESMOKEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2011, 08:57 AM
  4. Head gasket kit question
    By ssheely220 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2011, 04:34 PM
  5. Head Gasket Question
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 11:31 PM
