Thread: Just Starting to Mod...Questions....
Results 1 to 20 of 40
  1. #1 Just Starting to Mod...Questions....
    Jan 2012
    Southampton MA
    For a background, my wife and I have owned an 04 Comp G since 2006. Its bone stock, been her car all this time, and is in near-flawless condition with 62k miles. My family has owned Grand Prixs since 1995, and this is the last one remaining I changed jobs, so I now have a demo allowance instead of a demo (Sales Manager for a Chrysler dealer). The Comp G was too good to let go, so we bought my wife a new 2013 Charger R/T with the Road and Track Package and the Super Track Pack. We have a fresh 6 year loan...then the car will be mine and we'll get her a new one. Until then, the Comp G is mine to love and nurse for the next 6 years. No reason to think I cannot...
    But, I would like some more power, the safe way. I am looking at ZZP's Stage II kit and an Aeroforce gage to start. I have access to 93 octane gas at all times (I know this is a problem in certain parts of the country). I am not opposed to headers, but am wondering if they had that much more advantage over a PLog for a non-drag car. I would like a cat back, not so much for increased performance, as I know the OEM one is good up to 300 WHP or so...I simply want something throaty. I do NOT want something obnoxious and "drony," however. I am considering the ZZP 3" as well as the SLP (I also own 3 Camaros, 2 of which have SLP exhausts...I'm a big fan of SLP). I am hoping a Stage II kit, full exhaust (headers if need be) and the right pulley with 93 octane gas can get me on my way. Will this get me much over 300hp, or do I need to do more?
    While this will be a daily driver first and foremost, I would love to have a car that if I went to the track, I could be in the upper 13s. I know stock these appear to be about a 15 flat car. I know KR is a big deal on Gen IIIs...my last DD years ago was an 01 GTP coupe that I never modded. I've already done a lot of searching and have some good ideas...just would like to hear from those more experienced than I with W Bodies. I've been an F Body guy for years, but have never modded a W car.
    Thanks!!
  2. #2 Re: Just Starting to Mod...Questions....
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    http://www.grandprixforums.net/showthread.php?t=67580
    This is the best place to start. And you may wanna check the For sale section for some of those parts, it could save you alot of money over buying the kit from zzp
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  3. #3 Re: Just Starting to Mod...Questions....
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    they are fun as hell to mod it all depends how much u plant o put in it how much you plan to spend all that cause if i could id do a new plog rear down pipe for better air flow get ride of the stock air intake go with an open cone and go for a slightly bigger cam ur also super charged so you can drop pully sizes do a cold air inter cooler most people drop pully sizes before anything else
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: Just Starting to Mod...Questions....
    St. Louis
    You're not going to get the 3800 to sound "throaty", like your F-bodies. Just not possible. You want more sound remove the resonator and stick a glasspack in its place. I'd def. read through the "Safely modding your 3800" thread a few times. It should get your ride where you want it without blowing it up.
  5. #5 Re: Just Starting to Mod...Questions....
    Dec 2012
    Where 4T65E's were born
    Youtube is a great place to get a heads up on what different exhaust systems sound like on the 3800. You may be disappointed though.
    Sold.
  6. #6 Re: Just Starting to Mod...Questions....
    Not knowing the stage packages, I took a look. The 2 says plugs, tune, 3.6, belt and a downpipe for the most part, right? The biggest increase you will find there is the removal of some torque management. TM is programming that attempts to keep the tranmission safe from the power available in the engine. Not that it's bad to pull out a little TM, just good to know.
    As others mentioned, you could likely save some money on the stage kit to put towards that exhaust you'd like.
  7. #7 Re: Just Starting to Mod...Questions....
    Jan 2013
    leavenworth ks
    ive heard some cammed and turbo 3800 sound really good
  8. #8 Re: Just Starting to Mod...Questions....
    I'd do headers, intake, and either cam or rockers. Should make a fun daily
  9. #9 Re: Just Starting to Mod...Questions....
    Jan 2012
    Southampton MA
    Let me rephrase a couple things...
    1) I know 3800s often sound about as sexy as lawn tractors!! That is why while I'd like to do a cat-back, frankly its low on my list. I've heard some sound pretty sweet with cams, but opening up the bottom end of this engine isn't too appealing to me at this point. I haven't even replaced a cam in any of the F bodies!
    2) How much difference is there in HP between headers and a Plog, at the level I'm looking to be at? Are we talking 10hp? 20hp? Just curious. I'm big on setting the car up right, and not cheaping out.
    3) Anyone know of a good shop in MA/CT to carry out the above work, plus something like RRs? I work 65 hours a week...I just don't have time to work on cars anymore.
    4) Finally, how much different will the car sound with, say, headers, a DP and the stock exhaust? Will there be any real change in tone?
    5) CAI vs. open cone vs. FWI...any final thoughts? I'm intrigued to think I could just throw a filter on the end of my MAF...but that seems so cheesy....
  10. #10 Re: Just Starting to Mod...Questions....
    Stock exhaust with headers no cat.
  11. #11 Re: Just Starting to Mod...Questions....
    Sep 2013
    NC
    Please avoid the glass pack ! U will sound like a bumble bee!! Flomasters are great to make them sound more "throaty", but it still won't be quite as loud as a z28, but almost!!
  12. #12 Re: Just Starting to Mod...Questions....
    Quote Originally Posted by Jason E View Post
    Didn't realize you were just up the road. I'd do the work if you need someone reputable.
    Personally I don't believe you'd notice a difference between headers and plog on the level you are looking to go. I had plog/DP when my Regal was SC'd, Gen V and 1.9's....Never held it back at all, actually that setup led 05CompGman to cam and others to do stuff as well.
    Sound.. there is a slight difference, morso a little louder in the cabin as you get rid of the double wall stock downpipe.
    CAI etc.. I've toyed with this in various setups/cars that I've had. I dislike the noise of a cone when the car is cold, and yet run one. I've also run the stock airbox with the Gen V/Rocker setup mentioned above and never had an issue getting enough air.
  13. #13 Re: Just Starting to Mod...Questions....
    May 2012
    Pittsburgh
    Looking for a reliable high 13 second daily driver, I'd do:
    - Colder spark plugs (AL605s or 104s)
    - K&N drop in panel filter
    - Either headers (more effective, more work, better bang for buck) or 3" downpipe (effective enough, less work, more expensive per gain)
    - PCM tune
    - 3.5 pulley
    Done-zo
    You could throw 1.9 rockers and a fenderwall intake into the mix too, if you want.
    I'd skip the PLOG. I had one on my Regal - saw no gains at all from it honestly, even after tuning - when I swapped the parts above from my '00 GS to my '06 GP GT I left the PLOG on the Regal. LOL
    Anyway, those basic mods really wake the car up, make it a lot more fun to drive in my opinion, and don't really muck with it's ability to be a daily driver. Anything beyond that starts to compromise daily driver reliability in my opinion. You could throw an intercooler on it and keep boost low, but that would kind of defeat the purpose of intercooling, etc
    Active Roster: 2006 Grand Prix GT - Supercharged/Intercooled 2005 Mustang GT - 2012 Impala LT
    Injured Reserve: 2000 Regal GS - 1993 Mustang LX
  14. #14 Re: Just Starting to Mod...Questions....
    Jan 2012
    Southampton MA
    Thanks for the heads up! I saw you were in Enfield and Googled Purple Dino Motorsports, but didn't find a site for you? Can you send me a private message with your contact info? I wanna do something soon, and would like to speak with you directly!
  15. #15 Re: Just Starting to Mod...Questions....
    Jan 2012
    Southampton MA
    Quote Originally Posted by Swarzkopf View Post
    - PCM tune
    - 3.5 pulley
    Done-zo
    Anyway, those basic mods really wake the car up, make it a lot more fun to drive in my opinion, and don't really muck with it's ability to be a daily driver. Anything beyond that starts to compromise daily driver reliability in my opinion. You could throw an intercooler on it and keep boost low, but that would kind of defeat the purpose of intercooling, etc[/COLOR]
    Isn't there a major disadvantage sticking with a panel filter vs. a CAI or FWI? If not, I'm all ears...would love to have something I have clean less often!
  16. #16 Re: Just Starting to Mod...Questions....
    Jan 2012
    Southampton MA
    Reviving my old thread...still waiting to hear from BillBoost...may just have to send a PM!
    After a couple months spent doing some research, and thinking about how long I realistically want to keep the car, I've kinda decided I'm gonna go all out! I like having FWD for the winter, and I have an 07 Sierra Duramax I'll be paying on for the next 3 years. This thing is paid for...time to have some fun with it!
    So here's the plan...
    Powertrain:
    -Cone on the end of the TB...if anyone knows the part # K&N that fits, that will be my first mod
    -ZZP 1.0 PCM
    -ZZP downpipe
    -ZZP Plog (don't feel like spending the time/$$ on headers unless I find an awesome used deal on some stainless ones)
    -3.5 pulley
    -SLP or ZZP catback
    -Colder plugs (haven't done enough research yet to know for sure)
    MAYBE I will get into some RRs...not sure yet. Maybe if/when the valve covers start to leak, it'll be the perfect excuse!!
    Appearance:
    -Changing my 42% legal tint to 35% illegal (been able to get 35 through MA inspections ok on my Camaros, dark enough to make a difference...)
    -SE front lip
    -Silver Refective concept Pontiac inlays on front and rear bumpers...black arrowhead overlay on nose
    Suspension/Chassis:
    -4 of these bad boys...
    http://www.tirerack.com/wheels/Wheel...All&sort=Brand
    -4 235/50/18s...either Continental or GY Eagle F1s
    -ZZP STBs front and rear
    MAYBE getting into something like 1" lowering springs...considering GXP-spec OEM Bilsteins, unless someone has a better idea. I don't want to go too low because I'd like to keep some ground clearance for winter use and not destroy the SE lip on icy snow piles...yes, I can see that happening.
    The car is mechanically perfect the way it sits, however I will be doing the second round of fluid changes next Spring (did them all in 2009...owned car since 06). I've never done the plugs before, so that will be the perfect time to do it. Thoughts on this setup is appreciated...wondering what might be out there for a good sway bar upgrade for a Comp G?
  17. #17 Re: Just Starting to Mod...Questions....
    Powertrain:
    -ZZP 1.0 PCM
    -ZZP downpipe
    -3.5 pulley
    -SLP or ZZP catback
    Appearance:
    -SE front lip
    Suspension/Chassis:
    Um, you do realize that the ZZP powerlog plus downpipe cost more than a set of Speed Daddy headers right?
    http://www.ebay.com/itm/STAINLESS-SS...8dc2e4&vxp=mtr
  18. #18 Re: Just Starting to Mod...Questions....
    May 2008
    Schuyler, NE
    I would never recommend to anyone to put headers on a daily driven car, unless they are TOGs or S&S. Otherwise, they are a headache.
    If I were you, I'd keep your exhaust completely stock, throw on an intercooler, 3.4ish pulley, injectors, and a tune. That will make more power than anything you have listed thus far.
    Also, you can't put an air filter on the the tb of the 04+ cars, because they have an external maf. You will need some couplers.
  19. #19 Re: Just Starting to Mod...Questions....
    How are headers a headache? I've had mine on my 98 and my 04 and they've given me no problems.
  20. #20 Re: Just Starting to Mod...Questions....
    May 2008
    Schuyler, NE
    Because they are always a maintenance issue.
  1. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  2. Well I'm Starting My Top Swap, Just Some Questions
    By grandamle91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2012, 07:32 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. 97 gtp not starting
    By billysmth555 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 02:04 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
