Thread: GTP Troubles - Big time
Results 1 to 20 of 20
  1. #1 GTP Troubles - Big time
    SE Level Member GTPJason's Avatar
    Sep 2012
    New Carlisle, OH
    I started having issues with my '00 GTP a few weeks ago. First it would stumble/hesitate once or twice a day. Then it gradually got worse. To the point where it would just die when I came to a stop. Then it wouldn't idle no more than a minute before dying and making a pop noise.
    I came here and searched and found that maybe the MAF was bad. I unplugged it idled and did not die. It was more drivable but it still sucked.
    Codes I had stored were P0300 and both O2s
    I put a fuel psi gauge on the rail, 43#, pulled pump assembly to verify no collapsed tube/hoses, cavitated sock... all looked good.
    I fixed my blown out resinator with a piece of straight pipe welded in. I installed a new fuel filter, & post CAT O2 sensor. STILL SAME PROBLEMS.
    I bought a new Duralast MAF sensor and installed it. It would not even rev past 2,000 RPM. Again, I unplugged it and it was drivable.
    I tooK the sensor back to the store and got another one. SAME THING. unplugged it and it was drivable.
    I bought a scan tool (actron cp9575) cleared the P0102 (from being unplugged) Plugged in the 2nd sensor and this is what I found.
    @ idle. the MAF #s would jump around from .67 to 1.30 LB/M
    FUEL trim short 4.x
    FUEL TRIM LONG 16.X
    I took back to the 2nd sensor and exchanged it for another one. SAME CRAP. unlplugged it, now it's sitting in the driveway.
    I'm lost and need some help to where I go from here. Thanks in advance.
    2000 Pontiac Grand Prix GTP: Black on Black, all stock
    1987 Buick Grand National: 3.8L stock block, Billet Main Caps/ARP studs, GT6776E, 3400 Stall, 55lb injectors, LT1 MAF-Translator, Turbo Tweak chip: 516 FT-LB torque, 16# boost-93 oct
  2. #2 Re: GTP Troubles - Big time
    clean the TB, check for vac leaks.
  3. #3 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    The MAP "HG is reading 10-12 " at idle and 16-17" in drive... Is this in tolerance?
  4. #4 Re: GTP Troubles - Big time
    Fuel trims @ 16.4.
    It's got a vac leak.
    Check all the vacuum lines from the TB, to the fuel rail, to under the blower snout, back around to the MAP sensor. Bet that one is dry-rotted/broken...it's a common issue. Also check the other vac lines on the three line tree on top of the blower/boost bypass valve on the front...along with the EVAP line going from the solenoid on the back of the supercharger to the TB.
  5. #5 Re: GTP Troubles - Big time
    -19 to -20 at idle is where it needs to be, in drive will be 1-3 less.
  6. #6 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Ok so my low vacuum #s and high fuel trim #s point toward a vacuum leak somewhere then?? Will this make the MAF #s bounce all over too?
  7. #7 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Tee under the snout is cracked all the down on the bottom side of course. I had to remove it to see it. Installing a new Tee. I hope this cleans it up.
  8. #8 Re: GTP Troubles - Big time
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Small zip ties can work in a pinch
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  9. #9 Re: GTP Troubles - Big time
    Quote Originally Posted by GTPJason View Post
    advance auto had the best T's i could find, they were small white t's. add a inch or so of new vac line to each side of the T, and put it in place of the old one.
  10. #10 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    I fixed the Tee. Found the 90ddg rubber fitting under the MAP was split too, fixed it. Pulled every vacuum line/tube/,fitting and inspected. Still only 13.3 "hg
    And stiil surges and dies at idle.... I'm lost.
  11. #11 Re: GTP Troubles - Big time
    Mar 2013
    Colorado - USA
    Try reading your plugs and see if you can isolate any cylinders that are running lean. Maybe you have an injector going out on you. In the process of pulling your plugs you can take a good look at your wires too. Might reveal a problem with those.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  12. #12 Re: GTP Troubles - Big time
    You said both O2's threw codes, you replaced the rear one. The rear one is for reading only, the front effects your fueling. I'd suggest fixing the known issue with the front O2, then try unplugging the maf and whatever you do..don't use a duracrap.
  13. #13 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Still only getting 13.3 "hg MAP. Car died on me every single time I came to a stop this morning.
    Billboost37 - Thanks for your reply. I did not know that the front O2 effected fueling. O2 #s look ok. they bounce from 035 - 800 mv nicely. Could it still be bad?
    I will order a sensor. My original MAF is absolutely junk. It just stops reading sometimes and sticks on a number like .21 lb/m or .68 or 1.3 and it will spike to 48.x at times during idle. What is a sure shot replacement MAF for these cars? I know on my Grand National I could not get a single reman MAF to read over 100 gr/s at WOT when it should be 255. The fix all for that is to convert to the LT1 Maf and use a "MAF translator" This fixed all my MAF headaches.
    Thanks,
  14. #14 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Quote Originally Posted by Shmoke View Post
    I pulled 1 plug out and it looked okay (light brown, no crud). I replaced plugs this past Spring time along with new wires. I ohm'd the coil packs too. All in range. Do the ignition modules normally go out on these cars?
    Thanks,
  15. #15 Re: GTP Troubles - Big time
    You tell me if you need a sensor. Here's what you said, which isn't enough information for me to say anything except...you said there was a code and for some reason decided to replace one that does nothing bad except set a light.
    On maf, I'd say hit up JY's, ebay or amazon. Get a delco/original.
  16. #16 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Thanks! Could the poor fueling cause the upstream O2 to throw a code if it's not reporting well? I will order a sensor and get it replaced, they aren't that expensive. Then I can rule out that. I guess I need to understand more how this engine management system works. Like Open loop/closed loop fueling and what sensors control fueling and how.
  17. #17 Re: GTP Troubles - Big time
    Tell you what helps us ...a lot is knowing the code and the name of the code. Honestly, because if you say got a P0171 Lean bank 1, technically that's not an O2 code and you don't need a sensor. If you have an inactive code..then you want a sensor.
    PS.. best way to learn is to have trouble, and look up the actual GM diagnostic on the code you find. I found gearchatter.com used to have all the pages from GM.
  18. #18 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    I took the car over to my Dads tonight and put his MAF on. It ran very well at idle and driving. So, I need a good MAF sensor now.
  19. #19 Re: GTP Troubles - Big time
    SE Level Member 40thAnniversaryTom's Avatar
    Aug 2013
    Middletown, NY
    I am having some similar issues with my 02 gtp... It runs fine up until I go into boost. then it sputters like it has a misfire. For some reason, the trans fluid has metal shavings in it, but I just had the fluid and filter changed. The exhaust has a leak due to the supports failing. The car has sat for the last 2 years and I just got it running about 3 weeks ago. I didn't start having problems until today. It is completely unmodified and my mother bought it new. All service has been up to date. It does have the auto headlight problems with the short under the fuse box which I fix by pulling the box off and pushing in all the connectors every 2-3 days. Any help would be appreciated.
  20. #20 Re: GTP Troubles - Big time
    Sep 2012
    New Carlisle, OH
    Update: I got a used MAF sensor installed and the car is running excellent. MAF #s are stable, fuel trim #s are good, and No CEL now for 40 miles.
  1. lot of troubles
    By crazymind in forum General Tech Discussion
    Last Post: 09-05-2012, 08:18 PM
  2. having filling troubles
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2012, 10:19 PM
  3. transmission troubles
    By gtpfreak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2010, 08:47 PM
  4. map sensor troubles
    By Schaum in forum General Tech Discussion
    Last Post: 07-07-2010, 06:28 PM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
