Thread: Doing CPS/random stall research...
Results 1 to 5 of 5
  1. #1 Doing CPS/random stall research...
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Hello again forum, it's been awhile since my last post, but as the life of my GTP progresses I find myself time and time again coming here, lurking the site...
    I have experienced 3 random stalls in the past year and 2 of them with-in a weeks time...
    I have read many things about the crank position sensor being the culprit 90% of the time, and others being MAF, bad battery/alt, fuel....
    Also, when I experience the stall, it has been while not moving, idling at either a light or in traffic...
    I have read somewhere if a battery is old, it can cause stall issues....Is this correct??
    I have a 4 year old battery that looks failry beat...(wet)
    The reason for my posting is that as life progesses, I have less and less time to research/repair/experiment on my vehicle...
    Just looking for some quick pointers to I can head in a semi straight direction before chewing up my time going on a not so straight direction...
    I can and will (if needed) bust out the cps, but I would really like to test a few things before going loco...
    Should I just unplug the MAF and drive to rule out the MAF?
    How old is considered "old" on a car battery?
    If heading down the cps route, I have the fsm, so I would just need time and tools...I would need a puller for the crank pulley, correct?
    I read also I need some bolts from Ace so to use the puller correctly? Anyone shed some light on this for me?
    Any advice would be greatly appreciated...
    GoldGTP
  2. #2 Re: Doing CPS/random stall research...
    Sacramento, CA
    Upon further review of the battery, I've found the negative side stud is corroded badly...Prob be my 1st, cheapie fix to see what happens...
    (sry for double post)
  3. #3 Re: Doing CPS/random stall research...
    cleaning the TB is also a good place to start.
    the battery should have a date on it showing how many months its life is. 4 years it could be at the end of its life span. a parts store can test it for you.
  4. #4 Re: Doing CPS/random stall research...
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Quote Originally Posted by GoldGTP View Post
    This problem is a TSB. The negative stud on the frame rail also corrodes heavily.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Doing CPS/random stall research...
    Sacramento, CA
    Thanks for the replys...Since the negative post clean-up, I have yet to experience any more stalls....Thanks
  1. Shifting Issues - Have done a lot of research but have some questions
    By 99FormulaM6r in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2012, 02:19 PM
  2. 2000 gtp random stall issue
    By Deltabull in forum General Tech Discussion
    Last Post: 04-26-2012, 04:19 PM
  3. St. Jude Children's Research Fundraiser
    By ZR1Vette09 in forum Off Topic Discussion
    Last Post: 03-05-2012, 07:52 PM
  4. PO301 code. Did my research and just need a little guidance.
    By transaman98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:54 PM
  5. 2006 GP GT - Modding research
    By GeeBee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 02:34 PM
