Thread: Can't drop down pulleys? Any suggestions
Results 1 to 20 of 21
  1. #1 Can't drop down pulleys? Any suggestions
    Banned
    Jan 2013
    maryland
    Hey guys I have a Gen V and the swap is goin on soon and eventually I would like to drop down pulleys but I can't take the stock pulley off because of this:
    Any suggestions? Could I take it to a machine shop? I was told the pulley puller bolt have broken on the stock pulley and its stripped and stuck on it..
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. #2 Re: Can't drop down pulleys? Any suggestions
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Take it to your local machine shop.
    They should be able to tig weld to the bolt and remove it. We do the same kind of things everyday.
    Don't try and drill it, it looks like someone has broken an eazout off in there already.
  3. #3 Re: Can't drop down pulleys? Any suggestions
    Nov 2012
    Madison
    When my 8mm snapped off I drilled a small hole dead center, pounded in a small finishing nail and used a pliers to twist it out.
    I had used anti-seize so it came out super easy.
    Somebody botched the hell out of that!
  4. #4 Re: Can't drop down pulleys? Any suggestions
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by spazzz View Post
    What size pliers?
  5. #5 Re: Can't drop down pulleys? Any suggestions
    Jul 2013
    Summertown Tn
    If you try drilling that your gonna go through a bunch of bits. If you don't destroy the shaft trying.
    Eazeouts are Very hard and you'll probably never drill through it.
  6. #6 Can't drop down pulleys? Any suggestions
    Cheapest option = buy a used gen v snout
    Or take it to a machine shop
    I wouldn't do anything to it before you make it worse and end up being more expensive to fix.
    04 Comp G.
  7. #7 Re: Can't drop down pulleys? Any suggestions
    Banned
    Jan 2013
    maryland
    Thanks guys I'll take it to a machine shop
  8. #8 Re: Can't drop down pulleys? Any suggestions
    Jul 2013
    Summertown Tn
    If you lived closer I could do it for you, but any skilled tig welder shouldn't have a problem getting it out. Might cost $20-30 bucks.
  9. #9 Re: Can't drop down pulleys? Any suggestions
    You could take it to a shop and they should be able to press the pulley off.
  10. #10 Re: Can't drop down pulleys? Any suggestions
    good idea
    I needed to get my MPS hub pressed on a bit more since my pulley puller decides to crap out on me and had the shop press it on further when I had my AC work done. Shouldn't cost to much since you have the SC off already.
    04 Comp G.
  11. #11 Re: Can't drop down pulleys? Any suggestions
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    if its a really cheap ez out you can usually shatter it with a good quality punch with a sharpened edge,
    at work I have special drill bits for drilling ez outs but they cost 70$ a piece
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  12. #12 Re: Can't drop down pulleys? Any suggestions
    Banned
    Jan 2013
    maryland
    Didn't think of that thanks guys
  13. #13 Re: Can't drop down pulleys? Any suggestions
    The Boss Iceman6669's Avatar
    Jun 2011
    I have heard a 3 jaw puller works great.
    2011 F-150 Yote powered
  14. #14 Re: Can't drop down pulleys? Any suggestions
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Quote Originally Posted by Iceman6669 View Post
    yeah that will pull it off but how will he get the new hub on? Unless im missing something that center hole needs to be open to press on the hub.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  15. #15 Re: Can't drop down pulleys? Any suggestions
    Jul 2013
    Summertown Tn
    Yep, he has to get the bolt out.
    A 3jaw will normally compress the threads at the end of the shaft so that's not a good idea even if it didn't have a bolt broke off in it.
  16. #16 Re: Can't drop down pulleys? Any suggestions
    Jun 2011
    I was making a joke directed towards Smutty..
  17. #17 Re: Can't drop down pulleys? Any suggestions
    Jul 2013
    Summertown Tn
    Oh, my bad. Lmao
  18. #18 Re: Can't drop down pulleys? Any suggestions
    And you would have let me do it Josh
  19. #19 Re: Can't drop down pulleys? Any suggestions
    Jun 2011
    I really would have...
  20. #20 Re: Can't drop down pulleys? Any suggestions
    But at least now you know better. I learned you
  1. Pulleys
    By jayroca in forum Wanted To Buy - Parts
    Last Post: 05-09-2013, 12:45 PM
  2. Suggestions. L67 balancer or use zzp ss pulleys wih l36 balancer??
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2012, 02:45 PM
  3. pulleys
    By jrob28 in forum Shops and Community Heroes
    Last Post: 12-29-2008, 09:02 PM
