Thread: Suggestions. L67 balancer or use zzp ss pulleys wih l36 balancer??
Results 1 to 2 of 2
  1. #1 Suggestions. L67 balancer or use zzp ss pulleys wih l36 balancer??
    Florida
    Ok in preparation for my topswap I'm planning out the remaining loose ends. I have the l67 balancer but was thinking if I went with zzp's sees pulleys I would not have to change the tensioner or the coil bracket! Also there would be a very small advantage on having just one belt. Does anone know if the snout needs to be modified to use the Ss pulleys?
  2. #2 Re: Suggestions. L67 balancer or use zzp ss pulleys wih l36 balancer??
    I do know you wouldn't be able to run a pulley smaller than 3.4 unless you found one for sale from a forum.
    Something you might want to consider.
    L36 passenger side dogbone mount breaks. Something else to consider.
  1. help with harmonic balancer
    By Alcalypse in forum General Tech Discussion
    Last Post: 01-13-2011, 09:04 PM
  2. Who has a zzp 8 rib balancer
    By Viperkill97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 07:08 AM
