Thread: rotten egg smell
Results 1 to 17 of 17
  1. #1 rotten egg smell
    GT Level Member solidsnake1972's Avatar
    Oct 2011
    Plaster Rock New Brunswick
    The other day i started to notice im getting a rotten egg smell from my car, i read it may be from a partially plugged catalytic converter. So my question is if i take the catalytic converter out and gut it is it going to make my engine light come on?
  2. #2 Re: rotten egg smell
    Possibly..google spark plug fouler trick
    04 Comp G.
  3. #3 Re: rotten egg smell
    Aug 2013
    Kitchener, Ontario
    Most likely the light will come on. If you gut the cat there's nothing cleaning up the emissions. The rear 02 will set a code.
  4. #4 Re: rotten egg smell
    Oct 2011
    do you know what size of fouler i need?
  5. #5 Re: rotten egg smell
    Dorman #42209 is the one I use haven't triggered a PO420 code yet...it's worth the $7
    04 Comp G.
  6. #6 Re: rotten egg smell
    Oct 2011
    Did you use 2 or just 1 fouler?
  7. #7 Re: rotten egg smell
    I used 2
    04 Comp G.
  8. #8 Re: rotten egg smell
    Oct 2011
    I used 2
    so you drill one out and leave the other alone correct?
  9. #9 Re: rotten egg smell
    Correct!
    04 Comp G.
  10. #10 Re: rotten egg smell
    Oct 2011
    cool, cause im doing this in the morning on my day off so a little heads up help's.
  11. #11 Re: rotten egg smell
    No problem it's definitely worth the $7 or so. Worse case scenario you didn't spend much trying.
    04 Comp G.
  12. #12 Re: rotten egg smell
    Oct 2011
    also my resinator is bad, i herd some people use glass pack in place of the resinator. Does it really make that much difference using a glass pack or straight pipe?
  13. #13 Re: rotten egg smell
    Quote Originally Posted by solidsnake1972 View Post
    If anything use a glasspack..straights pipes are loud! A glasspack is very similar to a resonator. Plus they're cheap I think you can get a thrush one from advance for like $30-40
    04 Comp G.
  14. #14 rotten egg smell
    The Boss Iceman6669's Avatar
    Jun 2011
    What year is the car?
    Edit: just looked at your avatar..
    2011 F-150 Yote powered
  15. #15 Re: rotten egg smell
    i got a 32 inch thrush glass pack for 25 at autozone.
  16. #16 Re: rotten egg smell
    Welp I almost had the price and place right.
    04 Comp G.
  17. #17 Re: rotten egg smell
    that was a in store purchase too. no discount.
  1. Help Please for 1994 Grand Prix SUBFRAME is rotten
    By Kanki in forum General Grand Prix Discussion
    Last Post: 03-19-2013, 01:11 PM
  2. Amp Gets really hot and smell a burning smell?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2012, 03:13 PM
  3. rear strut TOWERS rotten.... :(
    By guimond47 in forum Brakes/Suspension/Chassis
    Last Post: 08-09-2011, 09:39 PM
  4. 99 gt 3800 rotten egg smell
    By mikedinthecity in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-03-2009, 01:17 AM
  5. Nocking engine/smell rotten eggs...
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2009, 07:30 AM
