Quote Originally Posted by Booba5185 View Post
I would check the injector impedence with a multimeter, in fact, I'd check all 6 and compare. They should all pretty much be the same, if cylinder 3 is different, then replace the injector. I had this issue with my 2000 GTP and the connectors inside the injector plug were spread to far apart. I bent the connectors in so they'd make better contact with the injector itself, and no problems since.
Are the injectors the same for supercharged and normally aspirated ? I wonder where the best place to get injectors is ?
