Thread: Boost comes and goes during moderate acceleration.
Results 1 to 3 of 3
  1. #1 Boost comes and goes during moderate acceleration.
    Apr 2013
    washington
    When slowly accelerating only hitting about 3 psi of boost i can feel the car lag for a moment then back to normal then lag again. While this is happening i watch the torque guage and about 3 psi of boost comes and goes with the power loss. no codes. 180* thermo, Overkill pcm. what could cause this.
  2. #2 Re: Boost comes and goes during moderate acceleration.
    Max Cook
    Guest
    vac leak?
  3. #3 Re: Boost comes and goes during moderate acceleration.
    Apr 2013
    washington
    I found a vac leak the other day and fixed it but the problem has been here since before the vac leak and is still here. would a bad ground connection rob power like that like maybe if the alternator has to keep kicking on?
  1. Suspension Clunking Noises going over expansion joints and moderate bumps
    By Crispykit in forum General Grand Prix Discussion
    Last Post: 09-24-2013, 04:06 PM
  2. slight bog under acceleration, only making half boost
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2013, 09:32 PM
  3. RPM's jumping around during moderate accel
    By DeNoZZo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-09-2012, 03:32 AM
  4. first gear slips/shudders under moderate acceleration
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 04:44 PM
  5. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
