Thread: Supercharger Overhaul Questions
Results 1 to 2 of 2
  1. #1 Supercharger Overhaul Questions
    Cambridge, Ontario Canada
    Make outlet a "V" shape
    Remove bolt bosses
    Angle the edge of the outlet to match rotor angle
    Install new coupler
    Change SC Oil
    MPS on there as well
    Clean up inlet - unless this is going to cause major tune issues
    Anything else? Should the oil on the casing inside where the rotors sit be cleaned off?
    Any bearing maintenance?
    What bits did you guys use? Is it best to start with a sawzal or something then clean everything up? Carbide round bit maybe? Wood bit lol?
    2005 E55 - stock
  2. #2 Re: Supercharger Overhaul Questions
    I used a sawzall and then cleaned it up with a carbide bit and some stones.
  1. Supercharger questions
    By 2000supercharged in forum General Grand Prix Discussion
    Last Post: 08-29-2012, 05:04 PM
  2. zzperformance master overhaul kit questions
    By 04GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2012, 12:01 PM
  3. Supercharger questions, so new to this!
    By Stinkygrub in forum Engine
    Last Post: 02-22-2012, 10:47 PM
  4. Supercharger Questions
    By juggalette79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2012, 12:48 PM
  5. Supercharger and cam questions
    By basshead42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2010, 10:21 PM
