Will an n/a 3.8 alternater bracket work on a s/c 3.8
What he said ^
Horizontal bolt bracket for the 140 amp.
Vertical bolt bracket for the 125 amp.
The old horizontal bolt brackets had the water pump elbow cast in.
The later ones & vertical bolt brackets use 2 elbows.
99+ bracket is different than 97-98
03 shortblock 98 topend (aside from the coil bracket, which is a 2000) a lil more carification![]()
K kool
Went ahead and bought the alt bracket off the 01 l67 figured i could get replacements easier![]()
