Thread: no power under wot
Results 1 to 20 of 23
  1. #1 no power under wot
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    My car doesn't have any power under WOT and the kr shoots way up. But under half or 3/4 throttle the car pulls hard. Would a vac leak cause this? I have the po171 code and have blown smoke through finding nothing but I'm completely lost. Fuel pressure was good haven't check it while driving though.
  2. #2 Re: no power under wot
    OBD-II DTC: P0171 System Too Lean (Bank 1) read this, theres more to that code then a vac leak. bad o2, or maf could be the cause as well.
  3. #3 Re: no power under wot
    Dec 2011
    Decatur
    A good maf would kill the car if unplugged? O2 reads 450-980 something like that.
  4. #4 Re: no power under wot
    theres also a fuse for the maf, it turn the car off, then unplug the maf, start the car up if it runs better the maf is bad.
    check the wires to the maf, and o2 for damage too.
  5. #5 Re: no power under wot
    Dec 2011
    Decatur
    Sorry guys I've been busy with work and school starting back up. Maf sensor unplugged while car running kills the car. Car is a lot faster with 1/2 to 3/4 throttle. Wot is very bad kr shoots up and car just puts like normal driving. If going 1/2 throttle to 3/4 once I hit over 65 the po300 will illuminate but go away once let off. Would a vac leak cause this? Only code that comes up is po171.
  6. #6 Re: no power under wot
    clogged cat maybe then.
    does it sound like a vacuum cleaner with a full bag when you floor it? then the cel flashes?
  7. #7 Re: no power under wot
    Dec 2011
    Decatur
    Just got a new cat Friday. This also happens with open headers.
  8. #8 Re: no power under wot
    do plugs and wires yet?
  9. #9 Re: no power under wot
    Dec 2011
    Decatur
    Yea they've got about 500miles and the icm and coil packs.
  10. #10 Re: no power under wot
    did you unplug the maf while the engine was running? thats not how to do it.
    unplug it with the car off, then fire it up. if it runs better the maf is suspect.
  11. #11 Re: no power under wot
    Dec 2011
    Decatur
    O ok ill try that I did it while it was running
  12. #12 Re: no power under wot
    yeah, the car wont like it when its unplugged while running.
  13. #13 Re: no power under wot
    GT Level Member mkyota1's Avatar
    Daytona, florida
    I would try to look at fuel pressure under load. I would replace the fuel filter first and see if it runs better. Sounds like its starving for fuel.
  14. #14 Re: no power under wot
    Dec 2011
    Decatur
    Ok thanks guys ill get back with ya on the maf after lunch and check filter when Il off.
  15. #15 Re: no power under wot
    Dec 2011
    Decatur
    So i unplugged my MAF and tried driving it. It ran fine until i went to give it a little gas and it just died no stutter nothing just died.
  16. #16 Re: no power under wot
    Dec 2011
    Decatur
    Im gonna get a fuel pressure gauge tomorrow since i dont have a night class. What should running pressure be? WOT?
  17. #17 Re: no power under wot
    over 40 psi.
  18. #18 Re: no power under wot
    Dec 2011
    Decatur
    Ok and does that sound like a good maf?
  19. #19 Re: no power under wot
    Dec 2011
    Decatur
    How can I check it while driving the gauge won't reach inside the car?
  20. #20 Re: no power under wot
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Tape it to your windshield.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  1. Fan's no power
    By trigun87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2012, 08:49 PM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  4. How much power do i have
    By gp3800t in forum General Tech Discussion
    Last Post: 03-18-2009, 02:39 PM
  5. more power
    By snap on in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 10:01 PM
