Thread: Removing coolant from the engine
Results 1 to 13 of 13
2007GrandPrixGT Removing coolant from the... 08-08-2013, 11:34 AM
Scottydoggs Re: Removing coolant from the... 08-08-2013, 11:40 AM
2007GrandPrixGT Re: Removing coolant from the... 08-08-2013, 12:10 PM
Scottydoggs Re: Removing coolant from the... 08-08-2013, 12:17 PM
02NavyBlue Re: Removing coolant from the... 08-08-2013, 12:19 PM
2007GrandPrixGT Re: Removing coolant from the... 08-08-2013, 12:21 PM
Scottydoggs Re: Removing coolant from the... 08-08-2013, 12:25 PM
02NavyBlue Re: Removing coolant from the... 08-08-2013, 12:26 PM
2007GrandPrixGT Re: Removing coolant from the... 08-08-2013, 12:55 PM
Lishap Re: Removing coolant from the... 08-08-2013, 01:08 PM
02NavyBlue Re: Removing coolant from the... 08-08-2013, 04:45 PM
Z34Phoenix Re: Removing coolant from the... 08-08-2013, 09:32 PM
Scottydoggs Re: Removing coolant from the... 08-08-2013, 09:40 PM
  1. #1 Removing coolant from the engine
    May 2012
    Thunder Bay, Ontario, Canada
    I should have a jack and stands or even ramps but I don't. And I don't want to go to mr lube. I need to flush her from above, my plan was to unbolt the thermostat housing and remove the lower rad hose, and flush it out that way by pouring water from the top thermostat opening, will that flush the coolant from the engine it out? The rad is the easy part. I was gonna disconnect the heater core hoses as well and flush them? Does that about do it?
    2007 Grand Prix GT SE 3.8 S/C "The Black Beauty"
    1994 Chevy C1500 4.3L "One wheeler Peeler"
    love/hate relationship.
  2. #2 Re: Removing coolant from the engine
    you on the right track.
    the way i like to do it is to , pull the lower hose, drain the rad and engine via that way, then remove the t stat, put the housing back on, then take the upper hose off the rad.
    fill and flush the rad while the lower hose is off, then put it back on, push the upper hose down to a bucket, fill the rad with a hose, leave the hose on, now fire up the engine, run it till clear clean water comes out the top hose, then turn off the hose run the car till no more water comes out the upper hose.
    put the t stat back in, put the upper hose back on, then dump one gallon of straight antifreeze in the rad, ( not the 50/50 pre mix crap) then top off with water, let it idle till the fans come on, rad cap off, top off as needed while waiting for the fans to come on, once the fans come on the t stat is wide open, bleed it now. top off if needed cap it, your done.
  3. #3 Re: Removing coolant from the engine
    May 2012
    I want to use a flushing agent so I want to make sure it's cleaned out completely after I do
  4. #4 Re: Removing coolant from the engine
    then flush it, seal it back up, add the cleaner, drive it, then re flush it again.
  5. #5 Re: Removing coolant from the engine
    Dec 2012
    Where 4T65E's were born
    Prestone sells it by the gallon, use that. I prefer using a garden hose to flush, it will move the water much faster than the water pump ever will, and force contaminants out of the system. I do the radiator, block, and heater core separate at full city water pressure.
    If you're even more serious, do that and fill the system with all water minus one gallon, use a gallon of Prestone cleaner, and put it all together and drive with that cleaner and water for a week, then flush again and use pure antifreeze. Of course in temps 32°F +
    Sold.
  6. #6 Re: Removing coolant from the engine
    May 2012
    So all that was in my way is what I thought, the thermostat just has to come out and I can flush the motor right out from the upper and lower hoses, someone said something about a sensor in place of a plug that drains the motor but I'd rather just do it this way.
  7. #7 Re: Removing coolant from the engine
    theres no sensor to remove to drain, but there is a rad drain plug, dont mess with it, most of the time it breaks.
    letting it pump out the upper hose will clear all the coolant and crap from the engine for sure. it should even flush the heater core, but you can pull the hoses off the engine and hose flush that if you want, a good old back flush of the core is ok too.
  8. #8 Re: Removing coolant from the engine
    Dec 2012
    Yeah just remove the hoses/t-stat. Often stock, or more likely aftermarket radiators have a drain plug that gets stuck, and I always leave them in that case.
    Edit: is there an echo in here?
    Sold.
  9. #9 Re: Removing coolant from the engine
    May 2012
    Alright guys thanks, I just want to make sure the prestone flush all comes out, I guess it eats away at the rubber hoses if lots gets left behind
  10. #10 Re: Removing coolant from the engine
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    Nice glad i found this thread because i've been working on a coolant flush for the past couple weeks. I have just been driving around with water in it for a few days then draining at and adding more water trying to get all the old dex(orange crap) out of my system (been doing that every 3 days). But it just seems like it wont fully flush out so ill try it how you said Scotty. Thanks again.
  11. #11 Re: Removing coolant from the engine
    Dec 2012
    Man I have got to make a write up on this... flushing with a garden hose is the most efficient way, you can get 100% of the old stuff out. Anybody want a flush?
    Sold.
  12. #12 Re: Removing coolant from the engine
    Florida
    if you have the time you could always remove the radiator and lay it flat fill it with the flush stuff and then put it upside down and do a reverse flush just in case anything large was stuck in the upper side and didn't make its way down to the lower side of the radiator.
    when i replaced my radiator i was shocked to see a few pieces of grass that was between the AC and radiator that was unsee otherwise.
  13. #13 Re: Removing coolant from the engine
    a good way to clean the fins of the a/c core there and the rad is simply spraying it from the bumper side with de greaser. then hose it from the engine side out, you'd be shocked what comes out of some cars. especially after 10 years plus on the road.
  1. PLEASE HELP: Coolant leaked out when removing throttle body
    By RideWithPride in forum General Tech Discussion
    Last Post: 07-29-2012, 02:10 PM
