if you have the time you could always remove the radiator and lay it flat fill it with the flush stuff and then put it upside down and do a reverse flush just in case anything large was stuck in the upper side and didn't make its way down to the lower side of the radiator.
when i replaced my radiator i was shocked to see a few pieces of grass that was between the AC and radiator that was unsee otherwise.
