You do plan on having the bottom end assembled at a machine shop after they align bore it right? If you don't then you will have a 200-mile miracle on your hands. These engines do NOT last if this is not done. You will end up spinning a bearing and then lower end will be trash.
Also, don't forget that the bolts are TTY and aren't reuseable (other than the crank balancer bolt). Good luck with your build.
