Thread: Boost gauge line location
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Yeah what could it be? I've tried a standalone vac gauge and it also only reads 10.
  2. #22 Re: Boost gauge line location
    Maybe the fitting you used is doing that?
    Beats me really.
    I'd try sticking the line straight into the rubber T off the FPR to see if the gauge reads over 10.
  3. #23 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    FPR? But you mean just hooking the gauge directly up to that line without the plastic tubing line right?
  4. #24 Re: Boost gauge line location
    Fuel pressure regulator...
    Take the plastic line going to the gauge and stick it straight into rubber T off the FPR, see if the gauge reads more than 10. You may have to pinch it with your fingers to get a tight seal.
    If it goes past 10, your problem is within the "T" that you made with that brass fitting.
  5. #25 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    YOu can get a vacuum boost reading off of the fuel pressure regulator?
  6. #26 Re: Boost gauge line location
    Cleary you arent understanding me.
    The Fuel pressure regulator see's MANIFOLD VACUUM, its connected in a series with the other ports for vacuum on the motor.
    Take the line OFF the FPR, plug that plastic line from the gauge to the RUBBER T that you pull OFF the FPR, that will give you manifold vacuum.
    You don't stick the plastic line inside the regulator itself.
  7. #27 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Will that read boost as well?
  8. #28 Re: Boost gauge line location
    Quote Originally Posted by camopaint0707 View Post
    Boost line T-fitting.
    Okay guy.
    See this picture that you already posted.
    The metal thingy with the RUBBER T, on it already is the fuel pressure regulator. Seeing how you already have tapped that line and saw 10in/hgs and boost, of course its still going to read boost. Its a vacuum line thats going to MAP sensor.
    A guess at your problem is the Plastic T that you made. Make it back to normal and stick that plastic line into FPR T, see if that makes more than 10 in/hgs. I don't how to explain it any better, don't get confused over simple stuff here.
  9. #29 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Alright, that T-fitting was the one supplied by autometer
  10. #30 Re: Boost gauge line location
    id ditch that compression fitting T set up, stick that white tube ( that feeds the gauge) into a short piece of vac line, then into a T in line where its already cut.
    i bet the end of that white tube is pinched shut from cutting it, if you used dykes to cut it.
    check that the gauge side of this tube is open as well, cut it clean with a razor blade.
  11. #31 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    I checked the line and it was fine. But I'll try to not use that T-fitting.
  12. #32 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Fixed all the lines and it seems to be running better now. Taped up all the fittings and made sure there were no cracks.
  13. #33 Re: Boost gauge line location
    Tape doesn't fix vacuum leaks. Get new line if you think it's leaking.
  14. #34 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Did for me!!
  15. #35 Re: Boost gauge line location
    Antioch, IL
    silicone or go home
    2009 Challenger SRT8
    Expert at being gay.
  1. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
  2. Whats the best place to run a boost gauge vacum line??
    Last Post: 09-25-2009, 10:16 PM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
