Fuel pressure regulator...
Take the plastic line going to the gauge and stick it straight into rubber T off the FPR, see if the gauge reads more than 10. You may have to pinch it with your fingers to get a tight seal.
If it goes past 10, your problem is within the "T" that you made with that brass fitting.
