Cleary you arent understanding me.
The Fuel pressure regulator see's MANIFOLD VACUUM, its connected in a series with the other ports for vacuum on the motor.
Take the line OFF the FPR, plug that plastic line from the gauge to the RUBBER T that you pull OFF the FPR, that will give you manifold vacuum.
You don't stick the plastic line inside the regulator itself.
