Thread: Quick question about roller rockers
Results 1 to 19 of 19
  1. #1 Quick question about roller rockers
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Finally decided what I'm going to do with my build. Nothing much but its something. Headers and rockers. Just wondering what is the best option for rockers since I want to just leave the stock springs in because of finances and someone else will be doing it. 1.8 seems to be the best option but I did recall that someone made 1.84 rockers?
  2. #2 Re: Quick question about roller rockers
    Nov 2012
    MN
    Only other thing I will add once headers and rockers are on is a 3.5 MPS. That should be plenty to keep me happy for a while.
  3. #3 Re: Quick question about roller rockers
    Florida
    There has been a debate for a while that the stock rockers actually create more valve lift then a 1.8 roller rocker. it has something to do with the geometry where as the stock rocker approaches max life that the tip to valve contact drifts farther away from the fulcrum. where as a roller rocker maintains the same distance. It was also said that cars dynoed with stock rockers actually saw a HP decrease by switching to roller 1.8's
    I would say another option would be the ER rockers or mod'd 1.9's. Or go with 1.9 roller.
  4. #4 Re: Quick question about roller rockers
    Nov 2012
    MN
    Wow. Never knew that. I know intense pushes 1.8 and 1.9s but I didn't want to get real in depth with taking the springs out too and having to then add them and retainers. I'd do rockers myself but not 1.9s and springs, just seems like to much to go wrong lol.
    What are the er rockers? A zzp product?
  5. #5 Re: Quick question about roller rockers
    May 2008
    Schuyler, NE
    Just get modded 1.9 rockers and leave the rest stock.
    How many miles are on your motor? If there isn't a ton, you should be fine.
    But, if you can't afford to spend $75 on a set of springs and retainers, you probably shouldn't be modding your car.
  6. #6 Re: Quick question about roller rockers
    Nov 2012
    MN
    I have money to mod, but its not a priority, and the reason I didnt want springs, is because I wont be doing the work, If It was just rockers, Id do it myself, But Im not about to drop $350 for a set of valve springs installed..
    Car has 150K miles
  7. #7 Re: Quick question about roller rockers
    May 2008
    Schuyler, NE
    You should be ok with that mileage. Just get some modded stock 1.9 rockers, and enjoy.
  8. #8 Re: Quick question about roller rockers
    L76 springs/retainers are dirt cheap. (G8 springs...all together shouldn't run you more than $60~ at a dealer)
    I'd always worry about tired valvefloatin' 3800 springs with a spring rating a .4lbs. because they suck.
    And like stated, if you have the money to waste, get 1.95 rollers...only benefit is they're lighter.
    If not, modded 1.9's will work just fine.
  9. #9 Re: Quick question about roller rockers
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    If it were me I wouldn't even bother with 1.8 rockers go 1.95s with l76 springs or leave it stock. besides springs shouldn't be that much more to change once you have the old rockers off it's 1 minute to hook up an air hold 1 minute to pull the retainer 1 minute to replace the valve seal (which is a nice bonus) and just as long to put it back together, I think my whole set took about 45 minutes with 10 of that being looking for a retainer I dropped into a crevase.
  10. #10 Re: Quick question about roller rockers
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Roller rockers allow you to rev higher which would actually be more "performance" than the extra valve lift you would receive with stock non-roller rockers. General redline with stock rockers is around 6k roms. Roller rockers would allow you to rev to 7k. This is of course based on the power range of your cam.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  11. #11 Re: Quick question about roller rockers
    Have a decent size compressor or a buddy that has one? Just install the valve springs yourself.
    04 Comp G.
  12. #12 Re: Quick question about roller rockers
    May 2008
    Schuyler, NE
    Quote Originally Posted by ls1camino View Post
    Not sure where you got this from, but none of it is true.
  13. #13 Re: Quick question about roller rockers
    Laurel, MD
    Ok.
  14. #14 Re: Quick question about roller rockers
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Spend the extra money on a new set of springs.
    Currently, my car with 153k on the clock, has worn out stock springs. at 5500+ RPM I get lots of valve float causing quite the spike in KR.
    New stiffer springs, such as L76, are cheap and well worth the money spent.
    Do it right the first time, and thank yourself later.
  15. #15 Re: Quick question about roller rockers
    Mullet Member Wotgtp's Avatar
    Connecticut
    Please get stiffer springs if you're going to get a higher ratio rocker and putting them on 150k springs, or don't do it at all. It's no worth the risk of snapping a Tired valve spring to save $60-80 and have ****ty higher rpm power with worn springs. For $200, you can buy an air compressor, the fitting for the spark plug hole, and a lever type spring compressor. Less if you buy a poverty air compressor. Plus air compressors get useful really quickly, and if you don't/can't spend the money on it, I wouldn't mod the car at all.
  16. #16 Re: Quick question about roller rockers
    May 2008
    Schuyler, NE
    You don't even need a compressor. Move the piston to TDC, and let the valve sit on the piston.
  17. #17 Re: Quick question about roller rockers
    Nov 2012
    MN
    never knew there could be so many options, for just a minor valvetrain setup
    So what are my best option? Im seeing L76 springs, LS6 springs, 105# springs, some springs need certain retainers due to seat height.. Its all starting to get confusing on what goes with what lol .. Im guessing my best option is a modded 1.9 rocker, with what springs and what retainers? If the car need a rebuild down the road, I can pull the heads, cam etc etc, but I dont want to get that far into it right now, which is why I was just going to do rockers, but now Im thinking about doing springs, as Im sure they are pretty tired out, especially compared to a new 90# or 105..
    So I guess I will just do headers first, then keep an eye open for modded 1.9s..
    Also with just headers, no cat, should I be able to run a 3.6
    Will said the tune he sent was good for rockers, headers and a 3.5 , but since I wont be doing rockers ( yet ) I would still like to drop a pulley and at least get it all installed.. Im guessing a 3.5 on a GenV is to much with just an intake headers, and overkill pcm?
  18. #18 Re: Quick question about roller rockers
    Jun 2013
    Hollywood ,FL
    let me know how it goes once I get my car tuned and pulley drop rockers will be next
  19. #19 Re: Quick question about roller rockers
    Jan 2013
    Australia
    If stock rockers give more lift than a 1.8 roller rockers... surely it would be safe to run 1.8 rollers with a XP hot cam on stock heads?
    I'm getting a A2A installed soon for my m90... its a good option on our rwd Aussie commodores, very low intake temps and stupid amounts of low end torque increase... I have also decided to keep the rockers stock for the time being... Just not worth the risk on old stock springs for only 15rwhp. I will probably upgrading to L76 springs and 1.95 roller rockers at a later stage though.
