Thread: GTP stalling while driving...is it my crankshaft sensor?
Results 1 to 3 of 3
  1. #1 GTP stalling while driving...is it my crankshaft sensor?
    PA
    my 98 GTP is randomly stalling when I'm driving it's happened to me 3 times this week it just stops. I also had the tach die as I was driving down the road and the TCS light came on once I restarted it it was fine again.
    I've read this is most likely the crank shaft sensor is that correct?? if so how hard is it to replace?
    Thanks
  2. #2 Re: GTP stalling while driving...is it my crankshaft sensor?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Its your CPS, its easy enough with a little research. I did it and im not mechanically inclined. There are a few vids, the toughest part most encounter is getting that crank bolt off. All I can say is youtube!
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  3. #3 Re: GTP stalling while driving...is it my crankshaft sensor?
    http://www.grandprixforums.net/how-r...sor-60906.html
    sounds like a crank sensor to me too.
  1. 99 Gtp problems (stalling while driving)
    By titanfan12 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2013, 09:39 PM
  2. crankshaft sensor
    By sweetgtx98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-22-2011, 08:44 PM
  3. stalling while driving
    By otonopaz in forum General Tech Discussion
    Last Post: 10-19-2010, 03:40 PM
  4. 01 N/A 3800 stalling while driving
    By j1b1e1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 12:13 PM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
